Hello,
while Ref80 is more or less a raw burried zener, Ref81 is the more compatible competitor to ADR1001 in terms of functional capabilities.
Source of images:
https://www.ti.com/tool/de-de/REF81EVM
Nevertheless, specs for noise of the zener core slightly increased, as given by the preliminary but yet incomplete datasheet available on the TI website. For Ref80 it is specified to 0.12 ppmpk-pk (912 nVpk-pk) and 0.15 ppmpk-pk (1.14 µVpk-pk) for Ref81. That is at least similar to LTZ1000 specifications with 1.2 µVpk-pk, but still worse compared to ADR1000 (900 nVpk-pk) or ADR1001 (600 nVpk-pk).
It just so happened that I got my hands on a Ref81EVM, populated with an engineering sample of this new device (marked with X). Unfortunately, the binding posts attached to the board are Pomona 3670, so the nickel plated brass version. Hence why the first thing to do was to replace them by proper TBP1 copper binding posts that I had available thanks to the group buy and forum member pipelie.
For the last ~100 h I have monitored the raw zener output with a 3458A and 24 V from a lab power supply applied to both LDOs for heater (LM317) and zener (TPS7A49), drawing about 1.4 W of power after thermal stabilization within the cardboard it came in.
We currently don't have any specifications for the long-term drift due to the incomplete datasheet, but can only compare to the specs of Ref80, which states typ. 3 ppm for the first 1000 hours and 0.3 ppm for 1000 - 5000 hours.
The reference specimen on this board lost about 14 ppm within the first 22 hours, another 2-3 ppm on the second day and ended up drifting by -18 ppm in the first 100 hours and currently reads 7.58588 V.
I'm not judging the results, as initial drift is to be expected, I just present them as they are and keep going observing how that drift developes over time.
-branadic-
