i finish my array end of october ... i stops drifting around april .. in may , i use one of my 2001 for 2 weeks run it basically flat with 2 microvolts up and down as i believe it device itself ... as i mention early it 3 x 1399 LCC , connected by awg32, LCC has option of kelvin connection that i use , buffers and a final buffer. All circuit in the metal box, not really air sealed but close, and 7cm thick styrofoam box where it self heating to around +40C , resultant variation to ambient temperature around 6:1 , let say +6 outside +1 inside. it increasing to +15 microvolts during warmup. The power supply actually 2 one for references, one for heater as a negative. ( somehow it think negative are another 2 cents .. ) 1399 out of shelf not selected ... some errors i fix in the output circuit ... Ah .. total consumption for all 3 heaters 27 mA at 11.33V basically 100mW per LCC. I assume stable temperature environment and small dissipation also help in stability as heater less fluctuating ... and Zener i think ( not remember exactly) around 3-4 ma. I decided to feed all 3 as derivative from summing, not each itself.
so i'm thinking based on my stuff 6 month and it stop drifting ... as well i didn't noticed in off\on shift ..
