I find it really painful to keep a computer around for 3458s long term logging, right now I don't have a PC dedicated to it, so I use my laptop, so you can imagine it's very annoying. It is my fault and while I can dedicate a NUC or build a tiny SFF PC with a PCI-E GPIB adapter to do all this work, why not take it one step forward?
I was thinking it would be cool to build onto one of the open source GPIB projects, redesign the PCB layout from scratch and add a ESP32 to connect it to the local wireless network, all in a super compact form factor, as a "stick" as much as possible. The next step, which is key for this project, is to have the "stick" self-contained, you can connect to it and tell it to do things, but general idea is to have it ran a script or set of scripts in a trivial easy to do way, that does not involve logging into a computer and updating or running scripts. The next key thing is to log the data directly in the cloud, on Azure or AWS, and provide easy to access log pages from anywhere in the world, and from any device. Also best would be one stick - one device, to avoid annoying cables as much as possible.
