Author Topic: Allan deviation algorithm  (Read 10096 times)
Offline RandallMcReeTopic starter
« on: February 28, 2024, 10:45:59 pm »
I'm interested in programming a Teensy4.1 to output the Allan deviation of the voltage that is being monitored.
Is it feasible?
If so, does anyone have code for it?
Thanks,
Randall
Offline Kosmic
Re: Allan deviation algorithm
« Reply #1 on: February 28, 2024, 11:13:13 pm »
Is it feasible?
Thanks,
Randall
I usually search in github to get some ideas.
Exemple: https://github.com/topics/allan-variance
This one look easily portable to a Teensy https://github.com/SMAC-Group/avar
Edit: Ha just noticed they don't use STL libraries. You might want to chose another one.
« Last Edit: February 28, 2024, 11:36:59 pm by Kosmic »
Offline jfet
  • Country: um
« Reply #2 on: February 29, 2024, 01:20:56 am »
The math is well documented at NIST time and frequency section.  Bill Wrilley wrote a book , its on his web site http://www.stable32.com/ that documents time measurements.  That is were Allan deviation came from David Allan at NIST.  http://www.allanstime.com/
« Last Edit: February 29, 2024, 01:27:45 am by jfet »
Offline Kosmic
« Reply #3 on: February 29, 2024, 01:54:51 am »
The original article from Mr Allan
Allan, David W. 1966. “Statistics of Atomic Frequency Standards.” Proceedings of the IEEE 54 (2): 221–30. https://tf.nist.gov/general/pdf/7.pdf
« Last Edit: February 29, 2024, 02:33:30 am by Kosmic »
The following users thanked this post: MegaVolt
Offline cncjerry
« Reply #4 on: March 01, 2024, 04:51:53 am »
I think Tom Van Bak did a version of the code as well.  I have the code, can't remember if I converted it to Visual Basic or did that app in C.  Ping me if you get stuck.
Offline edpalmer42
« Reply #5 on: March 01, 2024, 07:11:15 am »
Note that Dr. Allan's work has been updated a few times.
So now, there's:
1.  Allan Deviation - which almost no one uses anymore.
2.  Overlapping Allan - very common.  This is now considered the 'standard' version.
3.  Modified Allan and its overlapping version.
4.  Total Allan and its overlapping version.  This is my favorite because it gives you a longer graph than any of the other versions for a given dataset.
There are others beyond that such as Hadamard and Theo 1.
Each version tends to inflict a heavier computational load than the ones earlier in the list.
A few programs that use Allan Deviation and some of its offshoots are Timelab, Stable32, Plotter, and Alavar.  Timelab is updated regularly, Stable32 and Plotter are not.  I'm not sure what the status of Alavar is.
Ed
« Last Edit: March 01, 2024, 07:18:21 am by edpalmer42 »
The following users thanked this post: ManateeMafia, Mickle T., RoGeorge, MegaVolt, Kosmic, miro123
Offline miro123
« Reply #6 on: March 02, 2024, 06:09:42 pm »
There many way to do it on Teensy 4.1
 1. C / C++ code
 2. micropython and import allantools.
More documentation including the python implementation on link below. I gues that python implemrntation is just a python writer on C++ library. It is low footprint and fast
https://allantools.readthedocs.io/en/latest/functions.html
