I'm sure there must be a few vintage bridges with detectors or galvanometers that haven't survived over the decades, or there is a need to enhance their performance. So this thread has an aim of referencing any efforts to fix or replace or improve the situation.
My first foray into this topic was preparing a preamp for a galvanometer in a PYE 7440 bridge from the mid 1950's (
https://www.eevblog.com/forum/metrology/null-detector-based-on-conrad-hoffman-design-check/msg5480467/#msg5480467.
I recently made another such standalone preamp to use with an Aneng AN8009 meter that improved its raw sensitivity from 5uVdc to at least 1uVdc. That was used with an ESI combo of 230B guarded wheatstone bridge and an 803 generator/detector which had a poorly performing ss detector from the early 1970's. The detector preamp is powered from a USB battery bank to allow non-mains powering.
It may just be ESI, but a mid 1960's 300 PVB (potentiometric voltmeter-bridge) I checked out earlier this year also had a poor detector, and ESI don't make it easy to repair their detector circuitry (not a simple assortment of bjt's and an unidentified chopper relay, and also sealed in a metal can). So whilst I've found the internal bridge and other parts etc of these vintage instruments are still typically in excellent condition/accuracy, the detector portion may make them less appealing to use.
I have an early 1960's ESI 250 DA RLC bridge on the bench at the moment, and its magic eye detector is not working. As an easy (for me) workaround, I have been using an audio soundcard and spectrum analyser software (REW) to act as an external detector. That has worked very well, as a modern audio soundcard has quite a low noise floor, and the benefit of fft spectrum plotting to null the specific generator frequency from the ESI 250DA makes it easy to resolve a null condition to the level of resolution that this bridge can achieve (0.1 to 0.3% accuracy).
Looking at the later ESI 250 DE bridge, I note that it uses a generator isolation transformer to allow an external generator to easy excite the bridge without the grounding issues that the DA model has. The benefit of such an isolating transformer would allow a modern soundcard to also drive the bridge at any specific test frequency, and to link the generator and detector for better fft capabilities.
I haven't noticed anyone using a soundcard/software for such use, and there may be other interesting ways that some have kept using vintage lab grade equipment, so would be pleased to hear of any.
Ciao, Tim
