They don't show much details, but chances are this is 1 resistor chain, like 9M , 900 K, 90 K and 10 K. The resistance values may also be lower (like 1/10) - have not found a value.
Depending on the resistance there will be resistor noise, but not much to be done about it. The resistor chain is made to start with a high voltage, like 100-1000 V. Starting with a lower voltage (e.g. 10V) one has the choice of high resistance and rel. high noise with the full chain and starting in between with less resistance, but also less divider steps then. So the divider would not be a good solution to go from 10 V to 1 mV.
In addition to the resistor noise there may also be thermal EMF at the terminals. There are other dividers for very low voltages: power coefficient and leakage is less critical, but thermal EMF and proper drive sense (quad junctions for steps in between) more important.
