Author Topic: Ultra low-noise, short-term stable references  (Read 12422 times)
Online Echo88
Re: Ultra low-noise, short-term stable references
« Reply #75 on: November 01, 2024, 10:33:50 am »
I havent yet tested my idea that thermal bridges (e.g. Vishay THJP) may be able to reduce the thermal gradients across components like your current limiter or relays. If youre interested to test it i can send you some for free.
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #76 on: November 01, 2024, 04:54:14 pm »
Thanks for the thermal bridge hint.
Yes, i will definitely try other geometries. This kind of current limiter (600V, some mA, low thermal EMF) can be a very useful part. It could replace the input protection resistors in vintage multimeters like the Advantest R6581T or HP 3457A, thus reducing noise. I would also use it to protect the multiplexer inputs of ADS1256 or ADS1263 setups.
By the way, similar circuits are used in power electronics, e.g. https://www.electronicdesign.com/technologies/power/article/21808402/a-better-way-to-build-current-limiters-and-circuit-breakers.
Image shows a first 10 V LiFePo4 set with its thermistor embedded in ETP copper. The copper part was pretty difficult but probably serves the purpose. Maybe the second one will be nice. Meanwhile leakage currents dropped to 2 uA.
Regards, Dieter
Online Echo88
« Reply #77 on: November 01, 2024, 08:28:49 pm »
While waiting for the new pcbs i thought about the mentioned paper https://www.wellesu.com/10.1142/s021947750700388x and tried to see whether it could potentially provide an interesting path.
However, some questions came up reading it:
Taking the square root of the used Power spectral density gives the usual Noise Spectral density, right? V²/Hz -> nV/sqrt(Hz)
They only mention/calculate the white noise contribution of the used voltage reference, current setting resistor and the dynamic diode resistances.
Yet their calculations seem to correspond to their measured curves in Figure 7, while they are working clearly inside the 1/f noise region. Cant make sense of that.
How did they arrive at the mentioned 8 x 10^-17 V²/Hz spec for the used AD586?
Attached is a general first idea how it could be implemented.
ADR1399 7.05V *2 gain stage provides the necessary >10V reference voltage.
The transistor stage Q1/Q4 provides the current to the diodes, without loading the OPA189.
The original SSM2220 are obsolete, but THAT320 arrays or similar should also be suitable.
Then again i just opted to go for 12x ZTX951 transistors (lowest noise according to AoE3, about 1€/piece) attached to a temp controlled aluminium core pcb, which would sit inside the already temp controlled chamber mentioned a few posts earlier.
The 12x diode connected transistors provide the wanted 10Vout by adjusting the flowing current through them, the heater stage keeps the 10V stable by minimizing the diode TC.
The paper only mentioned the equivalent diode resistance and doesnt go into depth about 1/f noise contribution of diode connected transistors, so i just thought its best to use low noise (low rbb) transistors for this job.
Offline Kleinstein
« Reply #78 on: November 01, 2024, 08:54:56 pm »
The heated diodes system is somewhat related to the idea we had here. In the article the temperaure control works as a kind of slow thermal low pass filter. I am not so sure if exactly this way is a good idea, as it may not scale so well to lower frequencies and it is easy to get temperature variations from the outside to add low frequency noise.  On the upside regulation of a thermal system is well known.  The case of Li cap (battery) and regulator for the voltage may actually be a bit on the slow side - especially for testing.
For the initial tests and learning one may think about a more classic super cap or even a large normal electrolytic capacitor. This won't work perfect, but could test of the correction loop works.
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #79 on: November 02, 2024, 11:44:49 pm »
The diode array comes with a TC of about -2 mV/K / 600 mV = -3300 ppm/K, while the LiFePo4 batteries i tested have around 12 ppm/K, a 278x advantage. In the paper they are looking above 0.1 Hz. Certainly ambient temperature variations are easier to suppress at short time scales.
I think the LiFePo4 averager can work at time scales of hours or days. And yes, the cells are terribly slow for development and tests. While i glued the cells into the copper block they already lost some charge. When i connected them again, i made a minor mistake that changed the state of the cells even more. One definitely needs an automatic controller to charge and balance the cells as fast as possible and make them finally track the zener reference. Otherwise the idea is useless.
The schematic is a possible starting point. It still needs some level shifters. As Kleinstein wrote above, resistor R13 won't be necessary, so optional or switchable. I have been using it to measure leakage current.
Regards, Dieter
Edit: The schematic isn't more than a sketch. The amplifier can't feed the 10R charger resistor. And there should be a hardware protection when reaching 3x 3.6V = 11 V total voltage for whatever reason. And the nullmeter needs its own battery tap in order to measure battery voltage independent of charger current and during output off.
« Last Edit: November 04, 2024, 11:04:14 am by dietert1 »
Offline Kleinstein
« Reply #80 on: November 03, 2024, 09:03:31 am »
I think the bancing part should have a way to turn it off all the way (e.g. via the FETs that are there for the protection anyway). Just switching the OP-amps to nominal zero current may not be good enough.  Once balanced and not using much charge / discharge it should be OK for the nex years, possibly the life of the cells.
The diode array has the high TC, but this high TC is also the way to do the adjustment / regulation. So they kind of need at least some TC to get regulation. The speed of the regulation part sets the lower limit for the useful frequency. This means that slow regulaton would be wanted to also get to lower frequencies. The analog regulator used with the diode stack works OK for relatively fast regulation, but gets more tricky with even lower speed. One kind of gets the RC leakage problem at the regulator instead of directly using it for the voltage.  At some frequency there should be a cross over where digital regulation can be better. Digital has no issue with integrator drift from leaking / bias.
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #81 on: November 03, 2024, 06:36:08 pm »
Meanwhile i made another current limiter with 2x BSP135, this time with a 150R resistor to get about 5 instead of 8 mA. Total resistance is about 200R. Also i turned off an external hard disk that had been running about 10 cm away from the thermal EMF test location. This time thermal EMF came out to be 0.5 nV for the low thermal short, 2.0 nV for the PTC 20R and 5.2 nV for the new BSP135 limiter. Its geometry is "folded" to make it more compact. Both mosfets are glued to a small piece of fiber isolation sheet. The JFET limiter is in a short piece of aluminum tube.
Regards, Dieter
The following users thanked this post: branadic, Kleinstein, iMo, Okertime
Offline branadicTopic starter
  • Sounds like noise
« Reply #82 on: November 03, 2024, 07:39:27 pm »
If you were located in Germany, I could have sent you a brass tube with glass feedthroughs and some parafine to make a hermetically sealed, oil-filled version of it, which should reduce thermal gradients between all components.
-branadic-
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
Online Echo88
« Reply #83 on: November 03, 2024, 10:31:20 pm »
Yeah, i missed the giant TC of the diode stack when posting and only recognized it later.
They dont mention the achieved oven stability or even the big TC problem at all, shame.
With about -3000ppm/K i dont think theres a single heater solution that would get it sufficiently close to useable, without an additional PTC component (which gives the standard Z-diode + diode ref topology).
I have two ideas apart from using Z-diodes for PTC compensation that ill test to see if they have merit.
Offline Kleinstein
« Reply #84 on: November 04, 2024, 09:36:29 am »
The diode stack solution would likely want a 2nd oven layer, to keep out external temperature variations and so that the critical inner regulator does not have to work that hard. The oven stability is not such an issue, as the regulation is from the target voltage, not actually the temperature.
It is still an interesting article to compare. One could be free to replace the diode stack with a chemical battery - though I don't think the batteries would like temperature variations that much.
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #85 on: November 14, 2024, 10:26:39 am »
Meanwhile i got the setup in the image, with 2x AD587 references, 2x chargers similar to my sketch above and 2x copper-embedded LiFePo4 10 V battery packs, everything in a card box. The setup is wired to a K2700 with a 7706 MUX in order to log six charger currents and the two thermistors inside the copper.
Charger circuit is based on OPA4140, MUX4053 and NOMCT 8x 5K resistor array. For battery protection there are BS170 mosfets with Rdson about 1 or 2 Ohm. They limit the gain of constant voltage charging to about 0.67 uA for each uV of deviation. Separate mosfets for force/sense could speed that up somewhat as the battery ESR is less than 80 mOhm. Until now the batteries exhibit a time constant of about a day near the desired state, so it may take a week to descend to the desired precision.
Until now i can see the expected noise hierarchy of the three batteries in each pack. That means the noise in the charger currents is already dominated by the AD587 noise.
Next step is the constant humidity, temperature and pressure oven. Later one may want separate ovens for the two filters.
Regards, Dieter
« Last Edit: November 14, 2024, 10:28:56 am by dietert1 »
The following users thanked this post: Kleinstein, ch_scr, iMo, Overspeed, Korchahin
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #86 on: November 20, 2024, 11:19:16 am »
Here i have a log of charger operation for battery pack A. During the night, when room heaters are off and temperature is decreasing slowly, charger currents are in the low uA range. Heater turn on in the morning causes discharge due to positive battery voltage TC.
Meanwhile there is a design for the oven(s). I printed two brackets to put the battery packs inside a Weidmüller K41 enclosure that i have been using for hermetic oven tests. One or two 9x7 cm boards will also fit inside. That enclosure will run at 22 °C, using TEC temperature control.
Each battery pack received a small heater to use the copper as an inner oven, running at 23 °C, 1 °C above outer oven temperature. See Kleinsteins remark above about double ovenizing the diode array. Yesterday i made a linear temperature control for oven B. I got a log of battery pack temperature, still exposed to ambient temperature. Heater power is 15 V times the measured current, so about 45 mW on average. Without the heater, the temperature curve would look like the one of pack A, so the heater adds about 1 or 2 °C. Once the battery pack goes inside the outer oven, temperature variations will be much smaller. One may need a digital controller though, as the large integrator cap won't fit inside the outer oven.
While working on the temperature controller i screwed up the charging state of battery pack B. So i don't yet have a charger log. Some more work until things can go inside the hermetic enclosure...
Regards, Dieter
« Last Edit: November 20, 2024, 11:34:04 am by dietert1 »
The following users thanked this post: Korchahin
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #87 on: November 22, 2024, 09:58:31 am »
Meanwhile i tuned the temperature control loop. The PID is now much faster, with the integrator cap reduced from 100 uF to 2,2 uF. The OPA140 now runs at a gain of 86 dB, retaining about 40 dB for negative feedback.
To my surprise the loop is still stable - probably due to the fact that there is about 1 cm in ETP copper from heater to thermistor. Temperature noise came down to about 100 uKpp, still exposed to ambient temperature change. During the night the controller runs into it's 6 mA current limit, when ambient temperature cools down more than 2.5 K below "oven" temperature.
This is to demonstrate the importance of PID controller tuning. A stable loop doesn't mean the controller is well designed.
The analog PID test wasn't a waste of time, although: 2x OPA140 at 15 V consume about 54 mW, while a ADS1256 + some PWM will be more like 40 mW and the ADS1256 does eight channels.
Regards, Dieter
« Last Edit: November 22, 2024, 10:05:38 am by dietert1 »
