Author Topic: BAOOST voltage regulator and strong magnetic field  (Read 1336 times)
Offline sasaTopic starter
  • Hobbyist in electronic
« on: September 17, 2017, 07:43:26 am »
I have bough several BAOOST voltage regulators in the past, as they have ON/OFF switch pin I have needed.
However, I have notice this in datasheet:
"( 8 ) When used within a strong magnetic field, be aware that there is a slight possibility of malfunction. "
No further explanation nor exact data. What exactly magnitude of magnetic field should be that malfunction? For instance on poles or near neodymium magnets.
Strictly theoretical question, if anyone have experience with or made any research.
The 30+ years professional desktop software designer and software engineer
Offline Assafl
Re: BAOOST voltage regulator and strong magnetic field
« Reply #1 on: September 17, 2017, 08:09:35 am »
I have never used these devices - but it is possible that one or more of the transistors and/or a resistor are dimensionally long enough for hall effect to be pronounced.
An example hypothesis would be that the current sensor would read incorrect current given a large enough magnetic field and possibly turn current limiting off (or let the device overheat).
I would take a neodymium magnet and touch the device and see what happens....
« Reply #2 on: September 17, 2017, 08:38:59 am »
Sorry, I have missed to insert datasheet link:
http://www.mouser.com/ds/2/348/rohm_BA00ST-SFP_Series-316518.pdf
I do not have any neodymium magnet, I would certainly perform such test myself .
