Looking over various threads on LTZ1000 buffers, I've seen various amp options and usage.
3458A itself is using LT1001 for the ADC references
Illya's FX reference is using ADA4522
AN86 was using LTC1150
Can an LTZ1000 reference project do better than ADA4522? That seems just the best op-amp all around, with a few similar options available from elsewhere, like MAX, but seems these options are not better, just different, with similar TC, noise, and power figures.
Interestingly, in AN86, LT1010 op-amp buffer was used as output power driver, but one could just use a plain old transistor. On this, it does not seem like much can go bad. Thoughts?
