Some background before I get to the topic. Many moons ago I made a thread on this section about a high current measurement setup. We ended up building one and already made interesting discoveries when comparing different suppliers in less than one month of usage
It is build from a few basic parts. There is a reference current transducer Danisense DL2000ID which is connected to their system interface unit. The output current is then turned into voltage within that box using their VOM1333-10 conversion module. The output voltage in 10V range is fed to a 3458A no1. The measured devices, be it open loop or closed loop hall effect (at the time of writing) are fed through a mux into 3458A no2 which is triggered synchronously with no1. When building the system I had no idea how noisy the environment would be, so I chose the 10V conversion module instead of 1V.
The weakest link in this is the voltage conversion. It is specced
7ppm linearity
13ppm initial offset with 1ppm/c tempco
30ppm initial maximum ratio error with 2ppm/c tempco
Since the company is throwing a lot of money around and I need a master's thesis project some time within next year or so, we were thinking if improving this could be a suitable project for that. I've already been looking into Z-foil resistors for the shunts of the DUT measurements of transducers with current output and the datasheets look very appealing.
1 ohm external burden resistor also could be calibrated in the company cal lab comparing it to a primary resistance standard. At maximum current we run, it would have around 1W of power dissipation and utilize the 1V measurement range of 3458A
When looking at the VPG catalog there are many nearly identical specced resistors for shunt usage. Do you have long term experience with those? Also any tips on heatsinking, mounting and actual build of high precision shunts? I know we could just buy a Fluke A40B and call it a day, but the point of this exercise is to be a learning experience. For characterizing the end product, I also have access to weather cabinets.
Sorry if this discussion should've been kept to general resistor threads. I had a hard time finding DCCT related discussion
