Author Topic: C5-60T precision wire-wound resistor  (Read 2025 times)
Offline shodan@micron
  • Country: ru
  • Ampnuts
    • My personal page
« on: June 15, 2021, 01:15:12 pm »
void
« Last Edit: July 14, 2021, 05:17:52 pm by shodan@micron »
My lab in Instagram. LXI Instruments Data Logger apps.
I'm need tank of Bose-Einstein condensate....
The following users thanked this post: ramon
Offline doktor pyta
    • RF Scientific
Re: C5-60T semi-precision wire-wound resistor
« Reply #1 on: June 15, 2021, 03:43:59 pm »
Why semi-precision?
I'd say that hermetic sealing give them long term stability and make them suitable for metrology-grade applications.
P.S. I own 4 of these, all with T.C. of about 1ppm/C.
« Last Edit: June 15, 2021, 03:48:53 pm by doktor pyta »
Offline Mickle T.
  • Country: ru
« Reply #2 on: June 15, 2021, 06:26:40 pm »
No problem to buy a slightly better "thing" :)
Offline TimFox
« Reply #3 on: June 15, 2021, 08:45:28 pm »
The digital readout on the meter is a good example of why we must be careful with majuscule and minuscule prefixes:
1 P \$\Omega\$ = 1 kV / pA = 1 V / fA.
Offline branadic
« Reply #4 on: June 16, 2021, 07:52:57 am »
Looks like they used some insulator made out of PEEK. Could you take a detailed picture of how the leads are attached to the bobbin and how they attached the wire to the leads? Thanks.
-branadic-
Computers exist to solve problems that we wouldn't have without them. AI exists to answers questions, we wouldn't ask without it.
Offline wan1788
  • Country: ru
« Reply #5 on: June 16, 2021, 08:22:33 am »
-branadic-
In the third photo of the second post, there are folding petals.  They are clearly visible on the side cage. The resistor leads are made of magnetic material and have a high thermo efm.
Offline ramon
  • Country: tw
« Reply #6 on: June 16, 2021, 11:44:32 am »
I have count 160 turns. What is the diameter of the ceramic core? And the length between the first turn and the last one?
« Last Edit: June 16, 2021, 11:51:21 am by ramon »
Offline ramon
  • Country: tw
« Reply #7 on: June 16, 2021, 02:41:28 pm »
Thank you so much !!!
This reminds me some experiment I made some time ago. Will need to find time to continue ...
« Last Edit: June 16, 2021, 02:43:14 pm by ramon »
The following users thanked this post: Mickle T., shodan@micron, ch_scr, antintedo
Offline ramon
  • Country: tw
« Reply #8 on: June 16, 2021, 02:56:13 pm »
If the number of turns is correct, then I think that it should be 0.025mm wire.
    2*Pi*((7.487-0.025-0.025)/2) * 160 turns = 3.738 meters
    3.738 m * 2689 ohms/m = 10,052 ohms !
« Last Edit: June 16, 2021, 03:04:27 pm by ramon »
Offline ramon
  • Country: tw
« Reply #9 on: June 16, 2021, 03:32:57 pm »
Interesting   :popcorn:
Offline Andreas
« Reply #10 on: June 20, 2021, 08:49:23 am »
Hello,
not bad result.
for me additionally interesting would be if there is any hysteresis (or permanent shift) when cycling back to cold values.
with best regards
Andreas
