When I say cheap I mean cheaper than these Mueller hook clips at £6.52 each:
http://uk.rs-online.com/web/p/hook-clips/7148134/That is too expensive given I want to make up a number of sets of test leads. I suppose I could perhaps use cheaper for most leads and only use the Muellers for one pair but it would be easier to manage if they were all the same.
Also hook clips aren't particularly robust - either the plastic melts if you accidently put too much current through them or the hook breaks if it has been bent a few times.
Hirschmann make some with gold plated bronze contacts and gold plated Berylium copper banna sockets but I can't find any with gold plated copper contacts.
Has anyone found any decent quality Chinese clips? Many are dirt cheap but rubbish; more expensive ones may be equally rubbish with bigger profit margins.
