Poll
What items are people most interested in?
Passivated/gold plated copper binding posts 12/15yuan (Redtony/bbs.1ppm.cn)  Item:1/2
9 (11.5%)
Gold plated binding posts for reccesed inputs 17.5yuan (Redtony/bbs.1ppm.cn)  Item:3
12 (15.4%)
Raw copper binding posts 20yuan (nimolv)  Item:4
7 (9%)
Tellurium copper binding posts 20yuan (Qin Gong Xiao Jiang) Item:5
8 (10.3%)
TBP3/TBP2 binding posts 56/130yuan (Dishuo technology intelligent instrument)  Item:6/7
9 (11.5%)
0.8/1mm thick goldplated/passivated copper spade connectors 0.75/1.8yuan (Redtony/bbs.1ppm.cn)
10 (12.8%)
Tellurium copper banana plugs  14.4yuan  (Qin Gong Xiao Jiang) Item:3
5 (6.4%)
Tellurium copper banana plugs panel mount 28yuan (Advance my china) Item:4
4 (5.1%)
Premium beryllium copper banana plugs 32yuan (Advance my china) Item:5
4 (5.1%)
Pure copper tube banana plugs 7.25yuan (various sellers) Item:6
4 (5.1%)
Pure copper 0 ohm short (Redtony/bbs.1ppm.cn)  Item:1
3 (3.8%)
4 wire shorting PCB 5yuan (Nangong Yuyu) Item:2
3 (3.8%)
Total Members Voted: 19
Author Topic: Chinese Metrology accessories list  (Read 37482 times)
0 Members and 17 Guests are viewing this topic.
Offline gmac34
    • My GitHub with some EE projects
Re: Chinese Metrology accessories list
« Reply #150 on: May 22, 2026, 09:05:57 am »
Not sure, many things have gone in the basket now...
Offline gmac34
« Reply #151 on: June 11, 2026, 07:09:51 am »
these seem to be the binding posts that Marco Reps uses https://www.goofish.com/item?spm=a21ybx.personal.feeds.3.2b9e6ac2U55T7E&id=624047813302&categoryId=125958001 anyone knows this seller?
price is not bad, 2.5€ each (before shipping and taxes)
Offline grx
« Reply #152 on: June 11, 2026, 07:46:35 am »
Hello,
I just wanted to add a "measurement point" to the list, despite long discussions with the seller and hilarious digressions about copper and brass differences, these are definitely NOT made of copper.
https://fr.aliexpress.com/item/1005006396346537.html
It's just brass under the plating.
BTW, the plating is not an issue, it is very easy to remove with vinegar or hydrochloric acid. Copper is much less soluble in hcl than nickel. so this is a pretty fast operation, a few minutes max, and you can check the progress manually.
Thats why you can just buy plated copper lugs from farnell or anywhere and strip them of the nickel coating. very fine grit sandpaper can be used to clean the oxidation right before use. Or acid dip/wipe again since copper oxide is soluble in hcl. Dilute the acid, and dont let a pot of acid in open air, every steel within a foot will rust (dont ask).
Offline gmac34
« Reply #153 on: June 11, 2026, 10:05:39 am »
is it even brass? I'm pretty sure I bought the same a while back and found it was some softer stuff, it seemed casted rather than machined
Offline grx
« Reply #154 on: June 11, 2026, 07:16:31 pm »
Yes it is. It's not badly made, it's just not copper.
I attached the photo I sent to the seller.
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #155 on: June 11, 2026, 10:29:30 pm »
Where are people getting their low EMF binding posts from?
I was trying to buy some from the Chinese user here, but so far they don't really seem to want to sell any.
Does anyone have an alternative source that is acessible to buyers outside China?
« Last Edit: June 11, 2026, 10:32:52 pm by TERRA Operative »
Online PascalNETopic starter
    • Personal Website
« Reply #156 on: June 12, 2026, 12:24:23 am »
I used cssbuy.com which buys them for you and ships them to you. You just paste in the link from goofish/xianyu (look at first post for links). There's some discussion about in on this thread if you look. If you want to make a big order from one shop I wouldn't mind reaching out for you.  :-+
« Last Edit: June 12, 2026, 12:26:49 am by PascalNE »
Move slow and break things
The following users thanked this post: OneMoreMeter
    • Personal Website
« Reply #157 on: June 12, 2026, 12:31:39 am »
Update - It looks like my favourite pure copper posts from Nimolv and bbs.1ppm.cn(redtony) are sold out. I know that redtony is about to release some new posts (details soon) so I doubt they'll be back. As for the Nimolv ones I'll ask if he's planning a restock.
Offline grx
« Reply #158 on: June 12, 2026, 08:35:57 am »
TBH, I am considering finding just copper bolts or threaded rod and using 3d printed parts to build binding posts. I actually dont need bananas, pure copper spade terminals crimped on copper cables are the best option to avoid thermal EMFs.
    • Personal Website
« Reply #159 on: June 12, 2026, 03:22:56 pm »
Let us know of any developments at ~€2 each they were quite hard to beat but with copper prices rising I’d expect some justified price hikes.
Nimolv said he doesn’t plan on restocking them right now.
    • Personal Website
« Reply #160 on: June 26, 2026, 02:52:59 pm »
Added these https://item.taobao.com/item.htm?id=40823926055&skuId=61871554357 to the list. I know some may have purchased them so if you have a review I'd like to add it. Redtony (bbs.1ppm.cn) posts coming soon too hopefully.
Offline aronake
« Reply #161 on: June 27, 2026, 04:54:25 pm »
There are my base case terminals. Well made, seems to be good from TEMF perspective and very reasonable price. They also have the benefit of being able to unscrew the nut part of the terminal completely which makes cleaning easier.
The following users thanked this post: PascalNE
Offline gmac34
« Reply #162 on: June 29, 2026, 10:27:02 am »
Not sure what will happen to my copper... Beware that maybe it is not the best time to order stuff with CCS buy, it seems the did not prepare for the 3€ tax..
Offline gmac34
« Reply #163 on: July 30, 2026, 08:26:45 am »
Finally received most of my copper...
it was a very long journey
I'm very happy with the quality of the binding posts, as well as the spade connectors.
The binding posts are very similar to the Pomona, so they have a "classic" look and do not stand out, I can use them to repair some equipment with broken posts.
For my new cables I'm using this, https://it.aliexpress.com/item/1005003233879872.html a bit expensive but seems to be really silver coated and not tinned
to connect internally to the binding posts I have purchased this stile of crimp connectors, they appear to be copper, quite soft. the 3A fits well on the binding post shaft https://it.aliexpress.com/item/1005010193825635.html
If anyone has a better options for small wires please recommend it
these still require using a pretty think wire, with "signal" wire in the order of 0,22 mm² the crimp is not great.
I'm still waiting for a couple of TBP 3, just 2 for a special application, but I'm sure those will not disappoint.
The following users thanked this post: TERRA Operative, PascalNE, OneMoreMeter
Offline gmac34
« Reply #164 on: August 25, 2026, 08:41:53 pm »
Since I have some extra materials, If anyone is interested, I will offer custom made Low EMF cables.
More info here >> https://www.eevblog.com/forum/buysellwanted/(fs-eu)-custom-low-thermal-emf-test-leads-made-to-order/
P:S. I'm not sure what is going on with Redtony/bbs.1ppm.cn I have ordered a few more things from him about 20 days ago and still they are not shipped, the CSS buy staff says he doesn't answer their messages, hopefully he I just on holiday
    • Personal Website
« Reply #165 on: August 25, 2026, 08:51:29 pm »
I have been in contact with him about some things, he’s setting up  a new business that’s due to open soon. So he’s been very busy, he should be back to being able to do hobby things in September he said. So hopefully it’ll be despatched then. There will also be some new products coming soon, I’ll let you all know when we can order them as a group buy might be a good idea!
  • Country: jp
« Reply #166 on: August 26, 2026, 03:22:43 am »
I'm still in for a groupbuy of low EMF binding posts and bare copper and gold spade lugs.
The following users thanked this post: p-wave
Offline gmac34
« Reply #167 on: August 31, 2026, 09:41:01 am »
he has cancelled the order saying that the items are out of stock, so apparently both bare copper and gold spade lugs are not available, as ell as the banana to binding post adapter. not sure if it's that or he just doesn't have time to handle things
    • Personal Website
« Reply #168 on: August 31, 2026, 04:33:59 pm »
Yes, slightly bad news he said he's going on a business trip for two weeks but he'd give me a stock list after that. So I wouldn't expect anything to be despatched until at least the 15th of September. In the meantime have a look at this shop https://shop70023207.taobao.com/category.htm for lugs and other items. I tested some of these and the quality was good although they lack the passivated layer found on the redtony ones.  I actually sort of preferred the 0.7mm thick ones as they are much easier to crimp and easily accept smaller wires.
« Last Edit: August 31, 2026, 04:37:32 pm by PascalNE »
