Not having the 6 K 60K 600K for the range selection is a pitty, as ideally they should be matched to the other resistors. For stability (low TC) it would really help to have resistors from the same series as in the decade switches, especially the upper decade. Different resistors could limit the TC. Ideally the resistors from the decade should be low TC, to also avoid much heating effect, when used with a high voltage.
How much current the rebuild circuit could deliver is still to decide. A low current could be a plus for safety, though it would only be a current limit by electronic means. Transistor tend to fail short and thus not that much safety from such a limit.
