What do you intend the copper block to do? Copper is expensive and horrible to machine because it's sticky. Drilling holes is tricky and tapping them is even worse (very easy for the tap to clog and snap). Drilling and tapping using full fat milk as a lubricant works, but you need to clean up perfectly afterwards to avoid gone-off milk smells. For most purposes aluminium is very nearly as good and an awful lot easier to deal with. Methylated spirits is a good lubricant when drilling tapping aluminium.
Hello
Copper is not really horrible to machine :
The first problem is a lot of cutting oil brand stain the copper , a cheap and easy way to machine copper is plain milk
The second is the cutting angles I use HSS Co8 with cutting angle for aluminium
The third you need to flush all chips to avoid to smash chips between the tool and the part.
I agree than aluminium is very close and far easier / cheaper , use 5000 or 6000 serie , 6000 and 6061 / 62 are easier to machine that soft 5000 alloy .
Regards
OS
