Hi everyone,
I want to experiment with the stability over time of various voltage references which don't use ovens (mainly the three versions of the REF102).
For example, the datasheet for the REF102 specifies a stability of 20 ppm over 1000 hours, which are 40 continuous days of waiting. I want to test the medium-long term stability, but waiting for 40 days just to have a baseline to start doing the real measurements is a bit too much, especially if I want to test other references. I just can't wait months before doing measurements each time we want to try a new reference. It's for a univeristy project so i really don't have all the time in the world.
Is there a way to accelerate this aging process? I know there is because manufacturers do it all the time, but how to do it at home? I have a thermal chamber, but don't know the correct procedure...
Is it sufficient to cook the boards for a few days at a set temperature while powered on or maybe it is something more involved and difficult to achieve?
What do you say? Do you have any experience with aging components?
