Right I forgot about my little dynamic signal analyzer with 50KHz bandwidth, I was thinking about how much it could effect RMS (I also have that thermal RMS meter). I think that thing could be set to like 2KHz, and it went down to some 1Hz ?
That DSA one DOES have some nice filters.
You can turn off its AA filter but that makes it do some crazy aliasing on the display .
I need a clone
I might throw in some other ceramic res into a digikey cart, I only bought 1 per decade for looking at it with the impedance analyzer last year because there was no good information but alot of information on carbon composition.E24 ceramic resistor might be worthy to buy
I was visually looking at the impulse response visually and forgot about Q, if you do Q it does seem to dial in on 0.7 at ~417 ohms. But it does still have a "bump" on impulse when the Q is 0.7. I guess there is no right answer. At 510 ohms, there is no bump/ringing, but the Q is 0.57
For your values I got 0.62 Q factor BTW. But I am not taking into consideration the parasitic of the components
I do have the jim williams 100KHz active (analog) filter circuit that i built too, but I think that one has a HP of 5Hz built into it with the sallen key filters. HOWEVER I may have added a design change that I can just use the LT1028 gain stage without the filter on a auxillary output BNC, its possible that I might be able to use that box for amplifying this signal. It is in a steel enclosure, but it is hard wired with a 330uF polymer capacitor input. I suppose I should just build another amplifier, its fun.
About where to put inductor, EC8010
I got something to stop malfunctioning for a customer before by doing exactly that, kick the inductor out side the circuit. Its like a dog. It gets rid of stuff the actual electronics don't like. Industrial system stopped misbehaving. It was in a larger chemical facility that was having a issue with some data card. I thought its like putting a guard dog outside in the yard instead of having it in the living room. It would probobly be better if they let me have two inductors, aka leave the old one alone and add a new one, but it was a real cheap place, so thankfully I could just move it and it stopped doing whatever bad thing it was doing. I never heard about any measurements, but its for sure a valid strategy that the inductor might serve a better purpose on the input before the amplifier, because the complaint went away, and those people loved to complain. Very fortunate that someone put a inductor in the circuit, because if I could not just move it, then I can't have it on the circuit, because its a new expensive part! I don't know what kind of insanity that could have turned into if I was not fortunate to have that inductor there on the circuit board
