Author Topic: DC-accurate Low-pass-filter  (Read 8583 times)
Overspeed, Alex Nikitin, KT88 and 2 Guests are viewing this topic.
Online Kleinstein
Re: DC-accurate Low-pass-filter
« Reply #50 on: December 30, 2024, 12:39:58 pm »
Today one would ideally implement the 0.1-10 Hz filter to get the standard low frequency noise digitally. So the analog part with amplifier and ADC would have a somewhat larger BW (e.g. 0.01 to 1000 Hz) and the actual limits are set in the digital domain. This could also to an FFT or similar analysis. Even with a full analog filter it would help to have the accurate filter later, after some gain. The analog filters usually have some extra noise in the transition region that can be reduced this way. Normally 0.1 to 10 Hz is in a range where one would not use inductors, but active RC based filters.
It is only for ultimate DC precision where an inductor may get interesting again, as such a filter could handle the capacitor leakage better, possibly work with electrolytic capacitors. This would not be for noise measurement, but more ref. filtering (known to be difficult) or a PWM DAC.
For the scope preamplifier it depends one the scope that is used. The usual configuartion is to have the higher ranges with a divider in front and one should aim for the highest range that does no use the divider  - which range this is depends on the model. The lowest range that uses the divider may not be useful and have relatively high noise again.
The following users thanked this post: Victorman222
Offline EC8010
« Reply #51 on: December 30, 2024, 12:57:08 pm »
That's what I initially thought, but it turned out that if you want to measure the noise of a bench power supply, there are narrow (but high amplitude) spikes of digital clatter at high frequencies that can overload your amplifier, so for practical measurements it's worth having the filter before the amplifier.
In the end, it's all about dynamic range and trying to reduce the real world's dynamic range to fit within the very limited dynamic range of the oscilloscope's ADC (usually about 50dB, no matter what claims are made for 16 bit sampling). So although doing the filtering in digits is attractive, it leaves the ADC exposed to a very large bandwidth of noise and therefore possible overload. Of course, if you had a dedicated low frequency digitiser, you might well have much more dynamic range than 50dB and could afford to do the filtering in digits.
I've only measured using a Tek MSO54, but I don't imagine there will be a huge difference between oscilloscopes at that level. I measured the 'scope's self-noise, then calculated what external gain was needed to make its noise negligible compared to that of the amplified DUT. For a lot of work, x100 is adequate, but for really quiet noise sources, x1000 is needed. As you point out, you really want to operate the oscilloscope at 50mV/div rather than 1mV/div.
The "standard" 0.1Hz - 10Hz filter was done because it was practical and FFT measurements at the time were impractical. But that's no longer the case and we don't need to be constrained by such a crude method. A noise spectrum is far more informative than a single digit measurement via 0.1Hz -10Hz filter.
By the way, all of my measurements started as a means of measuring and taming voltage reference noise.
« Last Edit: December 30, 2024, 01:02:59 pm by EC8010 »
Offline coppercone2
« Reply #52 on: December 30, 2024, 05:25:25 pm »
Right I forgot about my little dynamic signal analyzer with 50KHz bandwidth, I was thinking about how much it could effect RMS (I also have that thermal RMS meter). I think that thing could be set to like 2KHz, and it went down to some 1Hz ?
That DSA one DOES have some nice filters.
You can turn off its AA filter but that makes it do some crazy aliasing on the display .
I need a clone
I might throw in some other ceramic res into a digikey cart, I only bought 1 per decade for looking at it with the impedance analyzer last year because there was no good information but alot of information on carbon composition.E24 ceramic resistor might be worthy to buy
I was visually looking at the impulse response visually and forgot about Q, if you do Q it does seem to dial in on 0.7 at ~417 ohms. But it does still have a "bump" on impulse when the Q is 0.7.  I guess there is no right answer. At 510 ohms, there is no bump/ringing, but the Q is 0.57
For your values I got 0.62 Q factor BTW. But I am not taking into consideration the parasitic of the components
I do have the jim williams 100KHz active (analog) filter circuit that i built too, but I think that one has a HP of 5Hz built into it with the sallen key filters. HOWEVER I may have added a design change that I can just use the LT1028 gain stage without the filter on a auxillary output BNC, its possible that I might be able to use that box for amplifying this signal. It is in a steel enclosure, but it is hard wired with a 330uF polymer capacitor input. I suppose I should just build another amplifier, its fun.
About where to put inductor, EC8010
I got something to stop malfunctioning for a customer before by doing exactly that, kick the inductor out side the circuit. Its like a dog. It gets rid of stuff the actual electronics don't like. Industrial system stopped misbehaving. It was in a larger chemical facility that was having a issue with some data card. I thought its like putting a guard dog outside in the yard instead of having it in the living room. It would probobly be better if they let me have two inductors, aka leave the old one alone and add a new one, but it was a real cheap place, so thankfully I could just move it and it stopped doing whatever bad thing it was doing. I never heard about any measurements, but its for sure a valid strategy that the inductor might serve a better purpose on the input before the amplifier, because the complaint went away, and those people loved to complain. Very fortunate that someone put a inductor in the circuit, because if I could not just move it, then I can't have it on the circuit, because its a new expensive part! I don't know what kind of insanity that could have turned into if I was not fortunate to have that inductor there on the circuit board |O
« Last Edit: December 30, 2024, 06:09:06 pm by coppercone2 »
Offline EC8010
« Reply #53 on: December 30, 2024, 10:17:02 pm »
Yes, Q = 0.57 = Bessel response, optimised for impulse. But the LC filter before pre-amplifier/oscilloscope is just there to protect the two from overload. Its impulse response doesn't really matter. What matters (slightly) is the in-band response before the roll-off. But it's easy to measure that and correct for it in the spreadsheet.
Offline coppercone2
« Reply #54 on: December 30, 2024, 11:29:40 pm »
Ok I windowed it nice and I guess I can see how from a FFT prospective something around 400 ohm seems the best for flatness but also not cutting off early but also not having a big bump. At the bessel point it looks alot different.
« Last Edit: December 31, 2024, 12:32:44 am by coppercone2 »
Offline coppercone2
« Reply #55 on: December 31, 2024, 09:59:09 am »
Ok, I put it together. I have two seperate boxes, one for the capacitor and the other one for the RLC filter, boxes with BNC, because I realized I already had cap couplers built up. I thought I might roll up a tube of 'iron' around the filter inside of the box, because its made out of aluminum.
I think this might be the first 'air wired' inductor I ever soldered. Very satisfying.
I do have a very large cap coupler built up already too, the thing on my mind is if I can get 4H out of one of those NC torroids. Then I can construct the lower value filter.
But I also wonder, why do you use a 470nF for 100Hz? Would a 400mH + 4.7uF be more reasonable? Why go huge on the inductor?
I found a inductor that is 1.4H @ 120Hz and 400mH @ 1KHz. It is tiny, 1cm cube
how does your 4H inductor look like frequency?
« Last Edit: December 31, 2024, 10:53:24 am by coppercone2 »
Offline EC8010
« Reply #56 on: December 31, 2024, 06:29:57 pm »
Beware the large coupling capacitor. If you connect it to (say) a 200V supply and switch on, couple a 200V transient to your oscilloscope or pre-amplifier. Thus, you need a shorting switch at the output so that the capacitor can charge without destroying subsequent electronics. Once charged, you open the switch. Doubtless, there are more sophisticated ways of dealing with this problem, but it works for me.
I went huge on the inductor because that's what I had in stock... But it's nothing to the 120uF 400V polypropylene also in the box.
The inductor is good enough and a SPICE simulation of the circuit will reveal the inductor's self-resonance (I've forgotten where it is).
Offline coppercone2
« Reply #57 on: January 01, 2025, 01:35:10 am »
I want more filters with inductors in them to build
Maybe a 60Hz notch filter ?
I wrapped the filter I made with a sheet of "pure iron" inside of the pomona bnc box, with maybe 3/4 inch of overlap. hard to form, but it seems to have 'seated' itself on those 4 solder points inside of the box when I bent it into place.
I bet if you really work hard you could make a full thing, but I think just putting it into a tube shape will help alot and be 0 work. I will tie it together with lace because I have it around and it will bearly fit with the cover up.
there must be some other filter to build for noise measurements in a box. Maybe a high pass to only look at the HF rejecttion capabiltiies?
I do have a few wave tek filter amps, but these little ones are very interesting
« Last Edit: January 01, 2025, 02:03:30 am by coppercone2 »
Offline EC8010
« Reply #58 on: January 01, 2025, 09:23:05 am »
I've found simple LC filters to be very useful and have made them in pairs to that I can put one before and one after the DUT, or tested two DUTs at a time to see which works best. I've made low-pass of 1kHz, 100Hz, and 10Hz, mostly in tobacco tins. A mains notch filter probably won't be too good because inductors invariably pick up a bit of magnetic hum from the mains transformers in power supplies, although rotating the inductor can often help considerably.
Offline coppercone2
« Reply #59 on: Today at 03:10:57 am »
I connected the LC filter between the multifunction synth (FM mod) and the 3054 oscilloscope and it showed me a satisfying bode plot on X/Y mode.
it looks like RLC filters do infact work  :-DD
with how much people hate low frequency signal inductors, I thought it might explode or at least have a inappropriate response.
a 36mH axial inductor, does actually work as theory describes
« Last Edit: Today at 03:13:06 am by coppercone2 »
Offline EC8010
« Reply #60 on: Today at 10:29:30 am »
Whoever would have thought it?
Online Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #61 on: Today at 01:04:30 pm »
The main problem with reasonably large inductive components is the susceptibility to external AC magnetic fields.
Cheers
Alex
