Author Topic: Designing bulletproof voltage standards  (Read 1030 times)
Offline MiDiTopic starter
  • Country: ua
« on: October 26, 2024, 03:17:38 pm »
There is a lot of information around the design of precision voltage references (e.g. LTZ/ADR1000, LTFLU, 1N829), but it seems there is not much information to make it bulletproof.
Scope:
- battery powered, but connector for charging/offline operation included (external charger/PSU is out of scope)
- typical 1..10V output (low/high voltage outputs are out of scope)
- enclosure with connectors (cabling and external components/instruments are out of scope)
- operation inside specified operating conditions for temperature, pressure, humidity (influence of those environmental conditions are out of scope)
Naive bulletproof design goals:
- Iout ±1mA DC & ACrms up to 1MHz
- unlimited short circuit to ±1.5kV DC & ACrms up to 1MHz with recovery to specs <1min
- ESD protection to highest classes of HBM/MM/CDM with recovery to specs <1min
- EMI immunity in rough environments
- immunity to capacitive loads with recovery to specs <1min after connection
- no significant degradation of performance/spec regardless of the applied disturbance
- DIY-able for hobbyist
What is your approach, design, knowledge, best-practice, ideas, specifications, goals, documents, links, ...?
  • Country: ua
Re: Designing bulletproof voltage standards
« Reply #1 on: October 26, 2024, 03:19:48 pm »
placeholder
Offline Andreas
« Reply #2 on: October 26, 2024, 06:29:13 pm »
Hello,
first: I would only spec features that I can prove per measurement.
(I guess that your EMI goals are out of your hobby budget)
Some EMI improvements are shown here:
https://www.eevblog.com/forum/metrology/emi-measurements-of-a-volt-nut/
My worst case scenario is a unintentionally direct connection to a 1000V calibrator
(which is current limited to some 10 mA and switches off within some ms)
So a 11V TVS diode should handle the mistake.
My references (LTZ1000 and AD587LW) are designed/proven to handle capacitors at the output up to 10 uF.
with best regards
Andreas
The following users thanked this post: MiDi
