Author Topic: DIY resistance standard banana plugs  (Read 1279 times)
Offline wizard1Topic starter
« on: November 08, 2017, 12:32:20 am »
I'm putting together the parts for a build of Dave's resistance standard and had a quick question. It looks like Dave used some Pomona style binding posts for his, are these the 3770 model or a knock off? I bought some binding posts off of ebay for this only to realize the resistance of the binding posts will contribute to the overall reading. I assume higher quality binding posts are called for here?
Thanks for the help!
Offline e61_phil
Re: DIY resistance standard banana plugs
« Reply #1 on: November 08, 2017, 09:18:29 am »
I've used the Pomona ones. And you should use four plugs instead of two for resistance below 100k.
