Author Topic: Advantest R6581 Schematic Diagrams  (Read 12841 times)
Offline z01z
Re: Advantest R6581 Schematic Diagrams
« Reply #25 on: June 26, 2018, 06:33:39 am »
Attached is the draft of the digital circuitry schematic from the analog out board. Seems like the same circuit is also used for the analog, printer and bcd boards, only the ID resistor is moved to a different position. Power-on test is successful and the different accessories are recognized when the resistor is moved around.
Moving the resistor to the scanner position gives 201 interface error though. After seeing the code this is not surprising, there are extra checks for the scanner, which checks some extra hardware.
The connector is Hirose FX2-52S-1.27DSL(71).
The following users thanked this post: Mickle T.
Offline serg-el
  • Country: ru
« Reply #26 on: January 30, 2026, 12:31:31 pm »
Power supply diagrams for the full (R6581) and reduced (R6581T) versions.
The following users thanked this post: Mickle T., picburner, Hydron, chekhov
Offline serg-el
  • Country: ru
« Reply #27 on: January 30, 2026, 01:24:59 pm »
Winding voltages are indicated at 224V mains voltage.
Offline Hydron
« Reply #28 on: January 30, 2026, 05:33:01 pm »
Much appreciated - I had already made some notes about my unit, but this is much more comprehensive!
Offline coromonadalix
« Reply #29 on: April 21, 2026, 12:29:15 am »
hi @ll can we revive  the 1st post   download links  or have other places to download, i've sent a pm  to the @op
Ko4bb is having problems   and links are dead
thks
« Last Edit: June 10, 2026, 12:16:23 pm by coromonadalix »
Offline Mickle T.Topic starter
  • Country: ru
« Reply #30 on: April 21, 2026, 05:19:04 am »
I've updated the link to the schematic diagram in the first post. Unfortunately, I can't restore the archive that was uploaded to KO4BB. I don't even remember what was in that archive :)
More recent information about the R6581 can be found in these threads:
https://www.eevblog.com/forum/metrology/advantest-r6581-service-manual/
https://www.eevblog.com/forum/metrology/advantest-(adcmt)-r6581-dmm-firmware/
The following users thanked this post: picburner, 2N3055
Offline Aipham
  • Country: vn
« Reply #31 on: June 10, 2026, 09:26:44 am »
Please help me !!!
My Advantest r6581 is very new and running perfectly, but I'm worried that the battery might be leaking because it's been used for a long timeSo I replaced the battery with a new, higher-capacity one, enclosed in a plastic case.
Offline Aipham
  • Country: vn
« Reply #32 on: June 10, 2026, 09:48:51 am »
After replacing the battery, it can no longer perform self-tests.
Fearing the solder joint wouldn't be secure, I soldered it back and forth multiple times,
causing the positive terminal of the battery's printed circuit board to come loose.
I tried to fix it. Currently, the positive terminal of the measuring battery is still connected to resistor R99, but the situation remains the same.
Could someone please guide me on what to do next?
Thank you in advance.
Offline Aipham
  • Country: vn
« Reply #33 on: June 10, 2026, 09:55:24 am »
The machine was brand new, and I was the first one to break it.
Please help me!
The following users thanked this post: aronake
  • Country: ru
« Reply #34 on: June 10, 2026, 10:08:55 am »
After replacing the battery, you need to perform INTCAL ALL.
Offline Aipham
  • Country: vn
« Reply #35 on: June 10, 2026, 01:30:48 pm »
Hi Mickle T, I really admire your knowledge of the Advantest R6581 in particular and your high level of expertise in electronics in general.
Can you guide me?
Please guide me on how to access the internal all screen.
Thank you very much
Looking forward to your reply.
« Last Edit: June 10, 2026, 02:23:17 pm by Aipham »
Offline Aipham
  • Country: vn
« Reply #36 on: June 10, 2026, 02:13:49 pm »
Its screen is like this, you know.
Offline deadlylover
« Reply #37 on: June 10, 2026, 03:07:01 pm »
MENU button > (press right twice, theres more options on the right) CALIBRATION (enter) > INTERNAL(right, enter) > ALL (enter)
Can you exit that error screen and open MENU?, maybe have to press right to read all message or press "ERR" or enter/exit to get out of it.
« Last Edit: June 10, 2026, 03:10:15 pm by deadlylover »
Offline Aipham
  • Country: vn
« Reply #38 on: June 11, 2026, 12:32:54 am »
Thank you very much, Deadlylover.
Unfortunately, none of the buttons are responding.
I can't get out of this error screen.
Unable to access the menu.
« Last Edit: June 11, 2026, 12:36:22 am by Aipham »
  • Country: ru
« Reply #39 on: June 11, 2026, 05:10:49 am »
This is an odd case, as a configuration memory check error shouldn't cause the keyboard to lock (unlike other selftest errors).
If you have a GPIB adapter, you can initiate internal calibration using the SCPI command CAL:INT:ALL.
The following users thanked this post: TUMEMBER
Offline Aipham
  • Country: vn
« Reply #40 on: June 11, 2026, 11:01:59 am »
Thank you for your reply.
I will buy a GPIB to USB adapter from Yahoo Japan. However, the delivery time is approximately 7 days.
Once I have the converter, I will follow your instructions and let you know the results. Thank you very much.
« Last Edit: June 11, 2026, 03:20:42 pm by Aipham »
Offline Aipham
  • Country: vn
« Reply #41 on: June 11, 2026, 03:17:51 pm »
While waiting for the GPIB cable to arrive, I have a question that I would really appreciate your help answering.
My Advantest R6581 was working perfectly. I only replaced the battery because I was afraid of a battery leak, which damaged the device.
When I replaced the battery, the device showed the error shown in the image above. However, when I removed the battery and turned the device on, it still displayed the same error message.
After repeatedly soldering and resoldering, I accidentally stripped the positive pins on the printed circuit board of the battery.
I suspect there is an open circuit on one of the wires connected to the positive terminal of the battery
However, when measuring from the positive terminal of the battery to R99 and pin 1 of the MAX695, there is still continuity
I suspect that damage to the anode (or even the cathode) of the battery's printed circuit board has resulted in an open circuit somewhere.
I only see a single circuit path from the positive terminal to resistor r99; I don't even know where the negative terminal is connected
There is no circuit diagram. If anyone knows, please let me know so I can check it specifically.
Looking forward to hearing from Mickle T and his friends.
« Last Edit: June 11, 2026, 03:19:44 pm by Aipham »
Offline Aipham
  • Country: vn
« Reply #42 on: June 12, 2026, 03:09:50 am »
Urgent!!! Sending Mickle T
when I hold the Home button and then power on -advantest r6581 shows this screen
[img]https://i.ibb.co/pjrHb8Yb/blob.jpg/[img]
Please guide me on what to do next.
In Diag mode, the buttons are working fine
« Last Edit: June 12, 2026, 03:11:29 am by Aipham »
Offline Aipham
  • Country: vn
« Reply #43 on: June 12, 2026, 03:11:54 am »
Offline Aipham
  • Country: vn
« Reply #44 on: June 12, 2026, 03:30:50 am »
Pressing and holding the Home button and turning on the power exited the error screen. I am performing an INTCAL ALL operation.
Thanks a lot to Mickle T and deadlylover. Thanks everyone for the feedback.
« Last Edit: June 12, 2026, 03:32:29 am by Aipham »
Offline Aipham
  • Country: vn
« Reply #45 on: June 12, 2026, 05:55:23 am »
By the way, with the admin's permission, I'd like to ask on this forum:
Does anyone have a set of four Vishay VHP resistors (2x68k, 120ohm, and 13k)
left over from their LTZ1000 projects? Please sell them to me.
Original
I would really like to buy a resistor set like this.
If I order from Digikey, I have to buy a minimum of 25 pieces of each type
Therefore, I have no way of buying this resistor set.
Offline bsw_m
  • Country: by
« Reply #46 on: June 12, 2026, 04:11:12 pm »
I don't think there's any point in replacing the original resistors.
At the same time, I recommend paying attention to the connection error of resistor R10.
Offline Aipham
  • Country: vn
« Reply #47 on: June 13, 2026, 06:50:39 am »
Thank you for your advice. I will check the electrical connector to r10.
