I'd pull the FRK and test it seperately.
It was available with two connector styles - seperate pins or a three row Winchester-style connector. If you're lucky and got the version with seperate pins, it's trivial to make the connections. In fact, if you've a dead ATX power supply, the female jacks on the 24 pin, 6/8 pin, or 4 pin power connectors are a perfect fit. Carefully cut the connectors apart and you end up with nice, insulated single pin sockets.
The full service manual for the FRK (including schematics and calibration info) is widely available online.
If the FRK checks out, you can then decide what your next steps are. Personally, I'd just put the FRK into a new box with a power supply. Without the chassis and the other modules (i.e. power supply and output splitter/amp) the module doesn't have much else that's useful.
Ed
