Hello
some further measurements:
LTZ#9 populated with ADA4522 as output buffer.
Capacitor 100nF across the output.
And a 100nF between Output Ground and ADA4522 (power) ground which fixes the layout error.
On the input of the ADA4522 there is a 4K7+100nF low pass filter.
And C9+C11 of my LTZ1047B schematic are also populated.
Measurement of 04.04.2020 shows -240 ppm deviation @ 60 MHz with 5Vpp Output level on the FY6800.
Measurement of 03.04.2020 shows improvement by the 3.5 windings on a EMI core suggested by Jason.
so -7.4 ppm @ 24 MHz as max deviation with 5Vpp output level.
At 20 MHz the ouput amplifier is switched so that the level is slightly different after switching.
And finally Measurement of 02.04.2020 shows best result with the Epcos 51 uH common mode choke for signal lines (CAN bus choke)
This choke already looked very promising when being measured here: (3rd last section)
https://www.eevblog.com/forum/metrology/emi-measurements-of-a-volt-nut/msg2684085/#msg2684085Result: -1.4 ppm @ 60 MHz with 5Vpp: so my personal target for EMI reduction is reached here.
Since the choke is now outside the LTZ#9 housing I will have a slightly worse result with the choke inside the housing due to parasitic capacities increasing.
With best regards
Andreas
Edit: picture of external CAN coil attached.
picture of output buffer ADA4522 with capacitors attached
By the way PCN 18_0171 has been updated on the Analog Web site: the new parts with the mask change will be available earliest mid of this year.
https://media.digikey.com/pdf/PCNs/Analog%20Devices/PCN_18_0171_RevB.pdf
