[ Specified attachment is not available ]I have a few pictures from a current calibrator model 5730A. This unit is at specification 30 minutes after power on (although I am sure that it gets much, much better over sustained power on). The construction is likely to be very similar to the 732C, barring the aluminum thermal block that houses the hybrids.
Note the thick, blank ceramic plates bonded to the rear of some of the devices. This is sililar to the Caddock thermally compensated resistor construction, where a second material helps compensate for mechanical expansion and contraction as temperatures change.
First, the front side of the reference. In the calibrators, there are two "stacked" references to deliver a higher Vref
Then, the rear of the reference board. Here you can see the heater element that covers the back of the ceramic PCB.
In a similar vein, the low voltage dividers on the switch matrix board. These dividers support the lower ranges.
And the rear of the divider.
