Author Topic: Extenders for Datron calibrators 4XXX, 47XX, 48XX  (Read 1754 times)
Online jfphpTopic starter
« on: April 19, 2018, 02:15:48 pm »
Back on  this old topic : extenders are finished, special connectors without edges and custom end allowing soldering on an extender, 5 keys supplied with each extender. A special one is not needed for the board with the self on the mother board. Extender is flexible enough to accept a little bend. You have just to saw  slots for the keys on your  calibrator (position of the key varies of course with the boards and for the kind of calibrator )
The following users thanked this post: quarks, voltampere
Offline cellularmitosis
Re: Extenders for Datron calibrators 4XXX, 47XX, 48XX
« Reply #1 on: April 19, 2018, 02:25:40 pm »
Where did you find card edge connectors without little plastic walls at the ends?
LTZs: KX FX MX CX PX Frank A9 QX
« Reply #2 on: April 19, 2018, 02:47:14 pm »
Made specialy for me according my specifications by a manufacturer. Not cheap !
Offline quarks
« Reply #3 on: April 19, 2018, 04:31:25 pm »
Looks very well made :-+
How much was the board and the connectors and is this one board working on all 48xx slots?
« Reply #4 on: April 19, 2018, 05:07:59 pm »
This extender is working for all the boards (picture is made with a 4808 motherboard) with an exception : the last row with one little connector
You can use for it a common ( HP for example ; pitch 2'54) extender as for the two connectors at the left of the calibrator for the power supplies boards.
Online Johnny10
« Reply #5 on: August 01, 2018, 06:12:04 pm »
What did they cost?
I have a 4000A needs some work.
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
