Hi, notfaded1
I've been reading this topic thread to while away the time whilst I await delivery of an Efratom LPRO-101 I'd ordered from a stateside dealer just over ten days ago now in the hope that you would finally break open the wooden box to reveal what I strongly suspect will be an undervolted FE-5680A.
For some reason I thought I'd seen a later posting dated May, hence this contribution. I guess it must have been a "Last Edit:" date/time stamp I'd seen attached to an earlier posting. Anyway, if anything, the absence of any report on what you found (if you ever did get round to cracking it open
) after more than four months since your last posting, makes the delay worse. Lucky for me that I've been reading 'ancient history' rather than following along in real time.
So, the unanswered question remains - did you finally discover what your "unknown Rb" frequency standard was? Before you dignify that question with a reply, let me first offer the reasons for my own prediction that it's most likely going to be an "undervolted FE-5680A" before you reply.
I could see from your photos that it was using a 12v laptop charging brick rather than the expected 19v one typically used to meet the minimum (single rail) supply voltage requirements of an LPRO-101 (19 to 32vdc, 24v recommended). That, along with what looked like a 5v smpsu board, initially suggested an FE-5680A until I checked actual voltage requirements for the FE Rb units when I discovered that they require 15 to 18vdc for the physics package as well as a separate 5v 200mA dc supply for the supporting logic, hence my referring to it as an "undervolted FE-5680A" which would neatly explain the much protracted warm up delay and the unsteady lock lamp indication.
I suppose it's just possible that the previous owner may have modified that 12v laptop charging brick to output 15 volts but that seems rather unlikely, judging from the use of a wooden box to house a Rb oscillator that needs to be mounted on a solid heat spreader thermally coupled to ambient air (fan assisted or not).
If I ever felt the need to modify a 12v laptop charging brick for use as an integrated 15vdc PSU, I'd be rather inclined to remove its guts and scrap the plastic housing to improve its reliability by allowing it to run some 15 to 20 deg C cooler.
Luckily for myself, I can just use a bog standard 19v laptop charging brick as an external psu without any need to increase its output voltage ( a ripple free 19vdc supply is just about the optimum for an LPRO-101 to minimise excess heat from its internal 17v analogue voltage regulator). I've no shortage of 65W and 90W rated 19v charging bricks to choose from
One final thought has just occurred to me regarding an outside chance of it being an LPRO-101 and that is: the 12v charging brick's output could have been placed in series aiding with the output from the 5vdc smpsu board to create a 17 volt supply, resulting in a similar undervolt condition unless the 17v analogue regulator had been strapped out of circuit inside the LPRO-101 module.
However, otoh, a 17 volt supply is nicely within the 15 to 18 volt range for the FE-5680A' physics package and the 5v smpsu, if it's being used to lift the zero volt rail of the 12v supply, can still provide the required 5v to the support logic rail.
It can be fun to speculate but could you please report whether or not you finally took the plunge and cracked open the box and, if so, what did you find inside?
JBG (still awaiting delivery of an LPRO-101 that's been stuck in a global air freight terminal in Erlanger, KY since last Thursday afternnoon
[EDIT 2020-08-25] It arrived yesterday afternoon, just before 12am. I've now got it trimmed to within 60ppt (2 cycles drift over a 9 hour overnight run) compared to my MK II GPSDO. I'm looking to improve on that calibration attempt once I've got it housed in a thermally regulated case.
