Ed-
Here's the time interval of both Rb overlaid. It looks pretty dang good I think!
Uh .... no.
Go back to the noise floor test you did yesterday. What did I say? "You also know that anytime you see a number at 1 sec. that's better than 5e-10, something's wrong."
Now look at the graphs. What's wrong with this picture?
Ed
I don't understand you said it looked pretty good and like the counter was working correctly??? I have my new cables and will try the test again when I get home from work. So the hint hint was that a little over 5 on the noise floor was a problem? Does this mean the counter has a problem then? Until I get my GPSDO working I suppose the only thing I could do is feed one Rb into the counter as the reference and measure the other then and see what happens? So I want the noise floor to be worse than 5E-10?
I can also try using the BG7TBL counter too but it doesn't work with time lab I don't think.
Bill
The noise floor test was perfect. It showed a nice straight line at the proper slope and the 1 sec. value of approximately 5e-10 agreed with the public specification. Then you posted two graphs that showed a 1 sec. value of 1e
-16, over
one hundred thousand times better than you could possibly measure. As Arthur suggested, those numbers are beyond the reach of standards labs. There
might by a few research labs on the planet that can reach numbers like that, I'm not sure.
This has nothing to do with cabling. This is most likely another data entry problem with Timelab.
It doesn't matter how many years you've been making these measurements. It doesn't matter whether you're an amateur or a pro. Dumb stuff happens. Buttons that should be pushed, aren't. Switches are in the wrong position. You wanted the third item on the drop-down menu and instead chose the fourth. You entered the wrong number in the fill-in box. I blame the dog, even though I don't have a dog. When you start a data run, look at
*all* the Timelab screens as the data is coming in. Do these numbers look right? Do the trends make sense? Can I explain why the numbers are as they are? If not, abort the test and check everything over. Think about what you're doing. Do it at the start of the test when you've only invested a few minutes, not after you've wasted a few hours or days collecting data that you now have to throw away.
Never trust the dummy running the test! The dog is smarter than him!
Ed
