Author Topic: Soo.. do I need to send my new resistors already back to PTB for recalibration?  (Read 2330 times)
Offline mzzjTopic starter
Got a slightly used standard resistor set..
 >:D
Need to wait couple of years to calculate 100-years stability for these  >:D
The following users thanked this post: babysitter, sipo75, HighVoltage, Henrik_V, lordium
Offline Henrik_V
  • “ground” is a convenient fantasy
Very nice one :)
Next year (2020) will be the next puplic day at PTB, usually in September.  It's every 2 years, so 2024 will match  ^-^
Pretty shure you will get at least some values in this case.
« Last Edit: February 15, 2019, 04:34:17 pm by Henrik_V »
Greetings from Germany
Henrik
The number you have dialed is imaginary, please turn your phone 90° and dial again!
Offline mycroft
  • Country: br
You missed the 1.69 ppm change from 1990. Wait a little bit longer to not miss this year's change of -17 ppb  :)
Offline Conrad Hoffman
    • The Messy Basement
Don't forget the 1948 change- https://www.nist.gov/sites/default/files/documents/calibrations/87mscohm.pdf
That's fairly noticeable when having old resistors certified in a modern cal lab.
The following users thanked this post: The Soulman
Offline babysitter
  • pushing silicon at work
Just want this thread subscribed.
I'm not a feature, I'm a bug! ARC DG3HDA
Offline HighVoltage
How did they measure 0.000 099 99 in 1924?
Impressive!
Offline The Soulman
  • The sky is the limit!
That was the NBS (national bureau of standards, USA) Ohm that changed (490ppm) to better match the SI (systeme international) Ohm.
Basically, the USA got it wrong and the pre 1948 was 490ppm to low.
This Reichsanstalt resistor was likely unaffected by this.
Offline Henrik_V
My eyes are old, and the picture not that clear.
Do the calibration report and the resistor match?
I read 36/1924 on the cal mark on the resitor (38/1924 in report)
and the serial number looks close but the last digit seems 0 (1656740?? )
and the 10 isn't for 10 Ohms?
Henrik
You are right. I didn’t get  the original! certificates yet and the example photos are not even from matching set. What really amazed me was that the original 1924 cal certificates were still together with the resistors.
Offline Henrik_V
Well, one major value of a calibration artifact is his known history. So you try to keep both together.
Henrik
