Added OPA27 which has input bias cancellation and it performs very well here! Interesting, didn't know about this....
OPA1611 was mentioned, I had it in there originally but removed it as it wasn't top notch in _this_ application. However it seems one of the very best in terms of THD. I also saw somewhere that it's virtually identical to OPA211. Anyway, I put the OPA1611 back in th plot.
Beware that early input bias current cancellation circuits caused distortion in audio applications. As I recall, this applies to the OP-27 and related parts and was one of the things that Linear Technology corrected in their LT1027. The Burr-Brown OPA27 dates back to at least 1984 so very likely suffers from this but I would need to see the detailed schematic to know.
To get noise data down to 0.1 Hz one might want to take something like 10 times the minimum 10 second interval to average over some random parts like popcorn noise.
Be careful doing this if you want to make comparisons to datasheet specifications for noise. Limiting the measurement to 10 seconds as is commonly done adds another pole into the frequency response. Making the measurement over a longer time period results in a different filter shape factor complicating comparisons with other sources.
The better way today is more like an FFT to get the noise spectrum.
This is what I would prefer down to 0.01 or 0.001 Hz which requires a 100 or 1000 second measurement and there is no reason to use AC coupling in the test circuit then.
On the other hand, the standard 0.1 to 10 Hz peak-to-peak or rms noise measurement with the proper filter shape is much easier to produce and more directly comparable to the datasheet specification. Note that operational amplifiers are not tested in production for this specification except in special cases like the customer paying a premium for it. Instead, a spot noise measurement at a higher frequency is made which correlates well enough with low frequency noise.
The 0.1Hz lower limit of noise testing seems too high a frequency, somehow... one gets the sense that this limit was chosen because it was possible to measure with reasonable equipment, rather than what we really need to know.
For example, if you have an instrument that you want to stay stable for hours or days on end, you really need to know the noise performance down to the milliHertz or even microHertz range.
AC coupled applications tend not to extend below 0.1Hz.
I have measured few wet-slug electrolytic caps, same as Jim used in his preamp.
They shown leakage <4 nA at 10V bias. Only problem is the cost.
On a parallell note, any leakage through the input cap would destroy the results. For high impedance inputs, tiny cap values require v-e-r-y low leakage while for the lowest noise amps, low input impedance requires large caps. Which E-lyths are good enough?
Some low leakage high voltage aluminum electrolytic capacitors can achieve similar performance but must be tested for burst noise.
For shunt capacitors in a filter, two capacitors can be used in series with the middle node bootstrapped with 10 times the input capacitance. This diverts the leakage to the output and minimizes the voltage across the top capacitor lowering its leakage. This is a common configuration for filters on precision references where excessive leakage would compromise DC accuracy.
In some applications, a DC accurate filter using an AC coupled operation amplifier is used.
I am thinking of setting this up again. would use
- Mechanical relay MUX
- A fA leakage input amp buffer (LMC660?) for the DMM, repeatedly checked vs a reference.
- A temperature controlled box.
The LMC6081 which is the lowest noise and highest precision of that series was the natural choice years ago but there may be some better ones now. The LMC6001 is a low bias current tested LMC6081 but practically all of the LMC6081s are 10s of femtoamps at worst and testing them is pretty easy with the operational amplifier configured as an integrator to integrate its own input bias current.
