Author Topic: Gertsch Ratio Transformer - maintenance  (Read 1101 times)
Offline RaxTopic starter
« on: March 25, 2023, 09:29:59 pm »
I just acquired a Gertsch PT-5 in good cosmetic shape. It seems very precise - just about on par with my RV722 DC divider (within the bounds of the expected accuracy of AC vs. DC of my meters, but frankly it is a bit surprising how exact it is).
The switches, though, are a bit fussy. This must have sat for decades. What have others done with this in terms of maintenance? Just work the switches to get them mechanically clean, or open it up and condition with some Deoxit? Unsure what would be advisable, though can't imagine the second option harming anything.
Thanks!
« Last Edit: March 26, 2023, 04:42:24 am by Rax »
Online Vgkid
Re: Gertsch Ratio Transformer - maintenance
« Reply #1 on: March 25, 2023, 10:24:09 pm »
The following users thanked this post: Rax
Offline Conrad Hoffman
    • The Messy Basement
« Reply #2 on: March 26, 2023, 03:45:52 am »
I'd use a small amount of Deoxit, using a toothpick or something, rather than spraying it everywhere. That should do it. FWIW, most of those ratio transformers are more accurate than similar resistive dividers. General Radio was able to specify them within 200 ppb!
« Reply #3 on: March 26, 2023, 10:34:07 pm »
I used a cotton swab moist with Deoxit (but excess wicked away), and then I placed the rotor contact "leaf" in between positions (so I'd have access to it) and wiped it. Mind you, the top and bottom deck don't have the rotor contact in the corresponding place - so I had to switch to different positions top vs. bottom to gain access to the rotor contacting leaf.
It seems all good now to me.
Thanks both!
« Last Edit: March 27, 2023, 04:44:42 am by Rax »
Offline guenthert
« Reply #4 on: March 27, 2023, 06:42:17 pm »
Google finds: http://manuals.repeater-builder.com/te-files/MISCELLANEOUS/GERTSCH%20RadioTran%20Instruction.pdf
If I understand the nomenclature correctly Gertsch PT-5 is the Gertsch Products RatioTran model 5, listed in their catalog as RT-5.  Or perhaps the renaming of the models happened when Gertsch became part of Singer?
« Reply #5 on: March 28, 2023, 04:22:20 am »
My questions exactly. As far as I can tell, the PT-5 and the RT-5 are the same unit. My specific one is apparently a "PT-5R," as I really wanted a rack unit. The vertical ones seem impossible to me from a practical standpoint.
Also, extremely precise as far as I can tell. I was able to dial different digits one by one; only the last leaves me a bit unsure, and the potentiometer has such fine effect it's difficult to convince my meter to react very convincingly, but I was able to fine tune the last count with fine and patient tweaks of the pot.
Very satisfying - an incredibly infinitesimally small but distinct and precise effect from RT just as I was able to see with the KVD. Wow.
