It looks to me like quality control of processes, on a manufacturing batch or session basis, provides quite a tight distribution around some varying mean. Sort of akin to the control process making a slight adjustment after some quanta of parts made. And that would infer that when a batch or session has resulted in say 0.5% then the whole batch is then 'binned', rather than individual parts. The span of values I hand measured was 92% within +/-0.25% for 100x 402R 1% bandolier, and 96% within +/-0.18% for 200x 10k 1% bandolier. That relates to part value variation and not an absolute value or tolerance spec, but seems reasonable for binning say parts to a +/-0.5% tolerance, when the same part has 1%, 2% and 5% spec rating options.
My initial effort on tempco similarly indicated that a statistically significant sample of tempco measurements on such parts then likely holds for all the parts on a bandolier - ie. a close distribution around a mean, rather than a scatter of pos and neg tempcos over the full range of the tempco spec. I haven't done a sampling of tempco of the 402R parts, but they seem to be well within their +/-50ppm/C spec, albeit noticeably higher than observed for the 10k parts I just got.
