Author Topic: how to wire in current probe to coaxial cable  (Read 880 times)
Online coppercone2Topic starter
« on: October 06, 2024, 11:33:50 pm »
I have a AC signal in a coaxial cable within the bandwidth of my probe (up to 50MHz).
What is the best possible way to wire in a probe to measure current?
The best I came up with is to get a open pomona box (metal box with 2x bnc connectors) and clip the probe in there. It seems like its the least intrusive way.
Offline jonpaul
    • IEEE Spectrum
Re: how to wire in current probe to coaxial cable
« Reply #1 on: October 07, 2024, 07:32:45 am »
If a BNC cable:
Bare BNCs><wires><BNC
Pomona BNC ><EZhook adapters
Otherwise just cut the cable shield, and breakout a loop.
j
An Internet Dinosaur...
« Reply #2 on: October 07, 2024, 09:00:52 pm »
I thought the box might be more 'coaxial' then splitting the cables, because its a big chunk of aluminum.
Another way might be to get a over sized braid with a slot in it that you put the probe into (like 1 inch braid), like a bulbous shape (puffer fish)
I basically made the same thing as this
https://i.sstatic.net/8I1fC.jpg
found on
https://electronics.stackexchange.com/questions/505674/measuring-current-in-coax-cable-using-clamp-on-current-probe
a split one can measure return current however. Maybe you would use a braid rather then a wire for the shield wire
« Last Edit: October 07, 2024, 09:07:50 pm by coppercone2 »
Offline jonpaul
    • IEEE Spectrum
« Reply #3 on: October 08, 2024, 04:38:45 am »
answer depends on the freq range of sig in the coax and of current being measured
j
« Reply #4 on: October 08, 2024, 04:40:08 am »
the widest range is the best because the probe can do 50MHz but the cable 4GHz. Ideally you want a solution that goes into the GHz for people that have the expensive probes (not me)
