@bateau020
1) Yes, it is correctly exposed
2) I have a block with the J02 option, which means there is no switch as such
3) Yes, of course
4) Yes, that's right
CAL: CURR: MEAS AC does not require the input of values, it just outputs an error
@little.tesla
Calibration of negative current does not pass if done according to the scheme with a load resistor, but passes if it is done according to the scheme with a 0.1 Ohm shunt resistor.
Yes, I disconnected all the wires for calibration CAL: CURR: MEAS AC, but I did not disconnect the sensor jumpers.
Please do not forget that my instance has the J02 option! I have an Agilent 66332a without this option and it goes through full calibration without any problems.
