Author Topic: HP ET 5188 (in-house) Voltage Standard  (Read 7670 times)
Offline cellularmitosisTopic starter
Re: HP ET 5188 (in-house) Voltage Standard
« Reply #25 on: August 20, 2017, 08:11:26 pm »
Here's an edited version of that pdf, which just has the circuit analysis, schematic, and parts list (attached).
It looks like the main reference zener is a 1N825.
The heated reference "can" might make a great training playground for gaining experience with building and tuning an oven and current driver for the 2DW232 zeners.
LTZs: KX FX MX CX PX Frank A9 QX
« Reply #26 on: August 20, 2017, 08:41:59 pm »
Oh wow, hparchive has a gorgeous copy of the 6101A manual (which has the same schematic as the 6116A), which appears to have been digitally reconstructed / recreated!  Perfectly legible!
http://www.hparchive.com/Manuals/HP-6101A-Manual.pdf
I've attached a similarly condensed / edited version.
Online Kleinstein
« Reply #27 on: August 21, 2017, 04:59:09 pm »
The HP 61xx supplies use a 3 stage differential amp in the oven part. The unit shown here is just a 2 stage differential amp in the oven. Also not very many transistors outside. So the circuit seems to be even simpler, but i could very well follow the general structure.
The temperature regulation looks like a simple proportional regulator. Not sure the oven part is that good to reuse it in a more modern application. The circuit is still from the pre OP era - such circuits today are usually OP based and thus look much different. Today a transistor couple is usually more expensive than a complete OP with in many respects better performance - so precision circuits today prefer OPs over the old style pairs.
« Reply #28 on: August 24, 2017, 05:29:52 am »
Thanks for your insights here.  I've been wanting to develop a better understanding of how op-amps work, so this is a useful circuit to consider.  Another thread on this forum advised studying the GAP/R P65 circuit, which was a primitive op-amp which only used 6 transistors.
Offline manganin
« Reply #29 on: August 24, 2017, 01:01:36 pm »
It doesn't need to be that complex. See the circuit attached: 3 transistors and 3 resistors (if you replace the current sources with resistors). Works fine in applications like audio if you remember the drive capability, gain and PSRR limitations in your circuit design.
The following users thanked this post: cellularmitosis
Offline Zucca
  • EE meid in Itali
« Reply #30 on: August 24, 2017, 01:54:23 pm »
cool, can't wait to see how this ends...
