If its a short, use a high current power supply set to a low voltage and a meter in mV range or less.
A 5.5 digit multimeter should be plenty, a basic 0.1mV resolution DMM can often work as well.
Although agree this is nice resolution. On the 20mR range this is driving 1A at max open circuit of 5V, 0.1uR resolution, 200k counts.
