Zlymex, fantastic job
P.S. Have You considered using typical laminate with copper (etched only near the connectors). Since You have guard rings this could provide better electrostatic shield. Was it due to the higher cost of this solution or the leakage in the guard divider string ?
Thanks very much. Probably I did not quite follow you, did you mean to cover large part of the board(probably both sides) with copper? I did plan this, and with copper ring on both side around the connectors, and make isolation rings to separate the guard and earth. That certainly works better. However, the insertion and separation of top part require a tremendous force, board of 3mm thick has to be used, the PCB manufacturer don't seem to do PCBs of this thick(usually 1mm to 2mm), I have to buy bare FR$ board(without copper layers, in any thickness such as 10mm) myself and had them cut by CNC machine.
In my current version, there is a gap between top and bottom which might affect the guarding connectors(which are high impedance) as well. I'm going to use flexible, insulated, earth-connected copper foils to wrap around the gap if that is a problem.
