[ Specified attachment is not available ]I'm using INA826 (datasheet
https://www.ti.com/lit/ds/symlink/ina826.pdf) instrumentation amplifier with 5k1 gain resistor (gain = 1 + 49400/5100 = 10.68x and 105.1mV on vref pin to get away from the bottom rail):
Up until 2V on the output everything is fine and output exactly matches calculated expected value. But above 2V it starts deviating. You can see it in this chart:
Notes:
- i tried 100k as a path to ground as datasheet suggest but it had no effect (the grounds of supplies are connected anyway so it doesn't matter)
- individual inputs are 525mV 275mV, difference is 250mV
- 100mV vref (actual value 105.1 remains constant during entire measurement), I separately measured it and it holds 100mV even at 47ohm load so it's not problem
So I can see 2 possible issues:
- Is something wrong with my schematic or am I making some wrong assumption?
For example 0.525*10.6 = 5.56 which is more than rail 4.5V, is this a problem?
- my instrumentation amplifier is bad?
Update:
- I did another measurement where I removed R7 so that voltages on inputs * gain never exceeds rail and it clips even sooner
