Author Topic: Is precision capacitor measurement with a DVM and signal gen possible?  (Read 3328 times)
Offline DAIRVINETopic starter
Is it possible to use a DVM and sine wave source and variable resistor to get a precision capacitor/inductor measurement?
I was thinking to have the capacitor in series with the resistor powered by a sine wave. Adjust the resistor so that the voltage across the capacitor equals the voltage across the resistor. Then use trig to find the capacitor value. Use a DVM to measure the voltage from the source, across the capacitor and across the resistor. What errors are there and how do we compensate for them? What sort of accuracy for L/C/Q could we get?
For reference I have a 3456A and fluke 189.
A bridge is not the idea because that requires precision capacitors/inductors.
A DE5000 is not the idea because I hope to make precision measurements with DVM and signal source and precision resistor. And improve the precision provided by a DE500, and also the input protection.
For example: With a 1uF quality capacitor, a 0.01% resistor, a 3456A(<90pF input), a decent (possibly filtered) sine wave source with frequency to ppm, can I make capacitor measurements to 0.05%? If the frequency is varied so that the voltage across the resistor is equal to the voltage across the capacitor/inductor, then we can calculate the value. What is needed from the DVM is precision, not absolute accuracy. If we can also measure the source voltage then we should be able to calculate the Q.
Sounds good, but these ideas are always full of holes. So what is wrong with this and what accuracy can be achieved? How can I compensate the input impedance of the DVM? (or low capacitance buffer)
« Last Edit: November 01, 2016, 09:15:29 am by DAIRVINE »
Offline kripton2035
Re: Is precision capacitor measurement with a DVM and signal gen possible?
« Reply #1 on: October 31, 2016, 10:24:04 am »
then the next device you could buy is a lcr meter like a deree de5000...
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #2 on: October 31, 2016, 10:29:49 am »
Yes, measuring capacitance and inductance like this is possible.
You have to bear in mind that the input impedance of the multimeter is going to significantly affect measurement of small capacitances, because impedances are going to be high (you are limited by the DMM to relatively low frequencies) and those 10Mohm and maybe tens to hundreds of picofarads on the input of the multimeter might make a difference.
The second thing you need to be aware of is that multimeters can only measure AC accurately up to tens, maybe a couple of hundred kHz. Again, not a problem with measuring fairly large capacitances (microfarads), but it does pose a problem with small capacitances, because the voltages across capacitors are going to be low.
I wouldn't know what sort of accuracy you can expect from these, because there are many sources of error in these sorts of measurements and all contribute to the final result. I think your best bet would be to get access to an accurate LCR meter to compare your results to and go from there.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline Henrik_V
  • “ground” is a convenient fantasy
« Reply #3 on: October 31, 2016, 12:07:01 pm »
always a question of precision ;)
here : http://www.sciencedirect.com/science/article/pii/S0263224110001089
a nice method is proposed using a generator, a DMM and build a low input cap. FET driver...
Basic idea: Use one (or more)  fixed know resistance (with low inductance) and change frequency until the ac voltage equals on both legs (using a 2P2T switch)
Like that the absolute uncertainty of the AC measurements at a given freq. doesn't hurt that much ... you compare two AC voltages of almost same frequency and magnitude.
Greetings from Germany
Henrik
Henrik
The number you have dialed is imaginary, please turn your phone 90° and dial again!
Offline setq
« Reply #4 on: October 31, 2016, 12:27:52 pm »
Yes. See: https://en.wikipedia.org/wiki/Bridge_circuit
Obviously the source is AC and you're measuring (or comparing) impedances instead of resistances.
Online Ian.M
« Reply #5 on: October 31, 2016, 12:37:06 pm »
If you use a Wien Bridge circuit, with a good enough potentiometer for the resistive side of the bridge, driven by a fully floating, low capacitance to ground source (e.g a transformer wound on an insulated ferrite ring with primary and secondary on opposite sides to minimise the capacitance between them) and a sufficiently sensitive meter, and have reference capacitors of significantly better than 0.1% accuracy, you can certainly determine a capacitor's value with 0.1% accuracy.  Even a hacked together breadboarded setup can easily beat 1%, with a cheap potentiometer if you determine the potentiometer's null position by taking resistance measurements from the wiper to each end of the track.
Inductors are a little trickier as if you use a reference inductor you have to take a lot of care to avoid any coupling to the inductor under test.  One can rearrange the classic Wien bridge circuit so the inductor under test is diagonally opposite a reference capacitor to avoid this issue.
Its usual to compensate for ESR or dielectric losses which make the capacitor under test appear partly resistive by introducing a variable resistor in the reference arm of the bridge. Then there are all sorts of refinements like active shielding, Wagner earths etc. to minimise the effects of stray capacitance however I'm not proposing to get into the details here.
Have a play with the attached LTSPICE sim then breadboard it and see how close you can come in real life.   If you are using a DVM for a detector, and a grounded signal generator to drive the bridge,  minimise the stray capacitance between the DVM and its leads and ground.  e.g. put it on an upturned plastic box to minimise capacitance to your ESD mat.  If you are using a scope for the detector, either you must use a differential probe, or transformer couple the signal generator.
