Author Topic: Datron 1281 on ebay  (Read 2740 times)
Offline BU508ATopic starter
Datron 1281 on ebay
« on: August 04, 2016, 06:48:40 pm »
there is a Datron 1281 for sale on ebay. Seller said, it comes with a DAkkS calibration certificate.
No biddings yet (starts at 3500 EUR).
Pity, seller will send this gear only to Germany.  :(
http://www.ebay.de/itm/282121828786
Andreas
Offline Dr. Frank
Re: Datron 1281 on ebay
« Reply #1 on: August 04, 2016, 08:39:03 pm »
Thanks for that hint.
Too expensive, though. Seems to be an accredited cal lab.
4ppm DCV, 15 ppm 10kOhm, 50ppm Vac only.
Not very promising for 1281 DAkkS calibration - Lab is not capable to do properly.
I fetched several electronics kits (elektor)  from Stolberg, I think, same road there, maybe 30 years ago
Our daughter was born the next village.
Anyhow, no deal for me.
Frank
« Last Edit: August 04, 2016, 08:57:28 pm by Dr. Frank »
Offline ap
    • ab-precision
« Reply #2 on: August 04, 2016, 11:13:05 pm »
Well, the 15ppm you refer to in the add pictures is not the cal lab, its the meter spec. The cal lab uncertainties add to that. Good thing: the 1281, other than the 3458A, has the ohms transfer accuracy specified. But price, especailly with these options, is way too high.
« Last Edit: August 07, 2016, 07:17:09 pm by ap »
Metrology and test gear and other stuff: www.ab-precision.com
