Author Topic: Siemens resistor decade, Oldie Restoration.  (Read 2206 times)
Offline Martin.MTopic starter
  • in Tek we trust
    • vintage Tek collection
« on: November 12, 2021, 01:46:56 pm »
Siemens Oldie:  R Decade 0 to 111,111 Ohm, wired with Manganin ( Isabellenhütte )
« Last Edit: November 12, 2021, 03:00:45 pm by Martin.M »
The following users thanked this post: doktor pyta, DH7DN
  • in Tek we trust
Re: just 4 a heartbeat: Siemens resistor decade, Restoration.
« Reply #1 on: November 12, 2021, 01:49:50 pm »
here is the picture from the problem inside.
1321433-0
tested with a needle. Begin of the cable = Mp0
Mp0 to Mp1: closed
Mp0 to Mp2: open
« Last Edit: November 12, 2021, 03:02:28 pm by Martin.M »
Offline NWerner
Re: Siemens resistor decade, Oldie Restoration.
« Reply #2 on: November 12, 2021, 11:04:40 pm »
I have a siemens&halske unit which uses same switch technology. Resistors look similar as well.
In my unit manganin wire was connected to copper wire (at least for thinner wire) for easier interconnections.
This manganin-copper connection is probably a weak spot.
  • in Tek we trust
« Reply #3 on: November 13, 2021, 05:50:49 am »
the green color between the both test point is oxidation ( Grünspan ).
Manganin is a copper mixed with around 15 per cent mangan, so easy to solding.
Not the same then the tungsten mixed wires for heaters, they are horrible in connecting.
If you have a repair, I have a NOS roll Isabellenhütte Manganin 69,7 Ohms/m, made 1985 = aged.
Offline Vgkid
« Reply #4 on: November 13, 2021, 10:21:08 am »
That is a nice decade, shame about the resistor. Thankfully manganin is solderable, so you can solder the two halves together.
Online Gyro
« Reply #5 on: November 13, 2021, 10:37:42 am »
It's nice to see Vaseline being specified as a contact lubricant for sliding contacts in decade boxes. I've always found it really good but it's good to see a manufacturer recommendation.
Best Regards, Chris
  • in Tek we trust
« Reply #6 on: November 19, 2021, 07:38:00 am »
fascinating:
the oldie is using abs. ohms instead of intern. ohms  :)
Offline Neepa
  • Mechanic by trade Electronics enthusiast by choice
« Reply #7 on: November 20, 2021, 08:38:56 pm »
No chance of those switch contacts tarnishing even if it's the 9th millenium and the 186th service cycle for the box.
Turbojet Mechanic playing EE.
