Right forum but probably not a lot of people into dimensional metrology! Flatness is always a problem because you need a bunch of points, and you need them in the problem areas. A simple warp isn't too bad, but things like edge roll-off are harder. I think profile means the same thing as flatness, if the profile in question is a plane. Collect your points and see what the spread is. Also, does the surface have any relationship to some other surface that further limits how far out it can be?
