Posting this here as I think this may be close enough to metrology/calibration that this would be the starting point; if not, please let me know?
Summary Question: I am looking for alternative to RG58 (same general diameter, but not that type specifically) for use in building some home-made RF patch cables usable to 6 GHz on a benchtop VNA.
(background/details)
I need build some short (typically 0.5-1.0M long) coaxial patch cables for benchtop use with a vector network analyzer for RF component/system testing up to 6 GHz. I need the cables to be N-male at one end, SMA-female at other end.
In this application, the cables will be subject to repositioning during use (i.e., between calibration and measurement phases, but not during actual measurements), so mechanical phase stability is a concern. Thermal phase stability is not a concern (room temperature only).
I prefer to use RG58 size (but not specifically RG58) cables as this size seems reasonable mechanically. RG58 itself is probably not a good choice (at least, poor RF shielding if nothing else.)
I don't wish to source commercially offered VNA test cables due to cost and I'd like to learn from the home-build experience.
Cable type options I'm aware of, with observations:
RG58 - OK cost, flexible (good), single braid shielding at best (bad)
RG142 - OK cost, double shielded (good), bad flexibility (solid center conductor, PTFE dielectric)
RG400 - OK cost, double shielded (good), bad flexibility (stranded center conductor, PTFE dielectric)
RG223 - OK cost, double shielded (good), bad flexibility (solid center conductor, solid PE dielectric)
RG223/U-02 - Very high cost (bad), double shielded (good), probably good flexibility (stranded center conductor, solid PE dielectric)
LMR195 - OK cost, double shielded (good), bad flexibility (solid center conductor, foam PE dielectric probably susceptible to phase shift during movement?)
LMR195 Ultraflex - OK cost, double shielded (good), probably good flexibility (stranded center conductor, foam PE dielectric probably susceptible to phase shift during movement?)
I could shift to LMR240 Ultraflex (can switch connector types) but remain concerned about foam PE dielectric vs. phase stability
Thanks for any advice, and happy to provide any needed problem clarifying information.
