Author Topic: APEX voltage reference on Mouser website ?  (Read 2445 times)
Online OverspeedTopic starter
« on: June 02, 2024, 05:15:08 pm »
Hello
During my quest of ceramic package for the Geller circuit I have loacted that on Mouser website
APEX VRE310AD with quite impressive performance
What do you think ? innovative or ???
Regards
OS
Offline iMo
  • Country: mn
Re: APEX voltage reference on Mouser website ?
« Reply #1 on: June 02, 2024, 05:30:20 pm »
Is it epoxy package?
Online The Soulman
  • The sky is the limit!
« Reply #2 on: June 02, 2024, 05:33:11 pm »
"Low-cost" should be taken with a pinch of salt.
Otherwise it doesn't seem to be to bad, on par with adr1001
Offline iMo
  • Country: mn
« Reply #3 on: June 02, 2024, 05:41:40 pm »
Based on its DS it is a standard zener with an opamp plus a resistive compensation network.
Most probably epoxy package. Perhaps at the epoxy LT1021-10 (or similar) level, or worse..
« Reply #4 on: June 02, 2024, 05:51:13 pm »
Hello
yes I agree but that a 100 USD IC .... a bit spicy compare to proven solution , except for limited room on PCB but keep this performance level with time can be difficult I think
Regards
OS
Offline iMo
  • Country: mn
« Reply #5 on: June 02, 2024, 06:08:33 pm »
Hello
Regards
OS
$100? For 100 pieces?  :D
Initial accuracy is good (much better than others, afaik), but there are the other parameters to consider as well. Take its DS and compare with any other voltage references.
« Last Edit: June 02, 2024, 06:15:06 pm by iMo »
The following users thanked this post: Overspeed
Offline Andreas
« Reply #6 on: June 02, 2024, 06:38:10 pm »
Hello,
I have 2 samples of VRE3050AS. (A 5V variant of the VRE310)
I got them from DIGIKEY near the change from Thaler to APEX.
(so quality may have changed since then).
It is a special (non standard) ceramic package.
But it has the same problems as all SMD packages (like LS8) when soldered directly to a EPOXY PCB.
One of the 2 samples had marginal T.C. according to spec the other on spec near room temperature.
But both had larger hysteresis than comparable references.
And both were noisy ~10uVpp against 3 uVpp in the datasheet.
Noise was even visible in 1 minute averages of my ADCs.
PSRR ~200uV/V output change demands for a well stabilized power supply.
So personally I find the price/performance ratio of a AD586/AD587 in CerDip Package is much more attractive.
with best regards
Andreas
The following users thanked this post: Mickle T., iMo, Overspeed, unseenninja
« Reply #7 on: June 02, 2024, 08:10:11 pm »
Hello
they produce other IC as
https://www.apexanalog.com/products/vre102.html
But for the price , there is more proven solutions
Regards
OS
Online Mickle T.
  • Country: ru
« Reply #8 on: June 03, 2024, 09:11:29 am »
It was quite interesting to study and write essays about the biography of the founder of THALER Corp. However, words cannot express how great my disappointment was in the quality parameters of the voltage references of this company.
There is currently a stock of VRE102M (with mil. spec) up for sale on one of the local marketplaces. However, I do not see any excitement among buyers, even despite the wholesale price of $35.
Offline HalFoster
« Reply #9 on: June 03, 2024, 12:02:19 pm »
I have a handful of the VRExxxx parts from when they were made by Cirrus and would second the opinions given above - they were marketed primarily for their initial accuracy and low (especially at the time) tempco.  They tended to be noisy and had a low to moderate amount of drift.  I have 4, of different voltages, that have been more or less constantly burning in for over 10 years now - it's been a long time since I did any long term tests so I guess that I need to blow the dust off and do that before long.  Anyway for high stability and relatively low cost I use the Maxim 62xx and 63xx series references - put them in a good filter/buffer and they will pretty much do anything that you need. For most all needs today though, just get a nice part, age it a bit and calibrate out any errors in software.
Hal
--- If it isn't broken... Fix it until it is ---
Offline iMo
  • Country: mn
« Reply #10 on: June 04, 2024, 06:37:05 am »
Those part are expensive because of their package. The ceramic materials, gold bond wires, gold plating, hybrid thin/thick film technology adds today a lot to the final "market price" (95% my guess). The reference itself could be kind of a "12-14bit ADC/DAC" parameters (at typical 10V FS it means something like 600uV resolution), however (as the most references we talk here were designed long time back for that purpose). This APEX ref is also expensive because of its trimmed initial accuracy, so good for a mass production of goods required such an initial accuracy. What people want in this section is the long term stability, low noise, low TC and the initial accuracy is not so important.
« Last Edit: June 04, 2024, 07:04:07 am by iMo »
« Reply #11 on: June 05, 2024, 05:49:12 am »
@IMO
Hello
Initial accuracy is an interesting parameter if and only if that able to be stable in time , trim something to reach a level of accuracy and lost the performance is a bit questionable except if that for an instant use as a rocket launch where electronic will be not recovered .
APEX dont claim their performances are not '' life time'' not include the noise if I read all the comments
Strange way to make production and marketing
Regards
OS
