The next step in this journey was to build the LM317 based HV regulator circuit. This needed more parts so it ended up on veroboard.
The interesting part of this design is how it allows a 40v device to operate at hundreds of volts. LB-47 describes how this is done.
Refer Reply #2 for circuit LB-47 page 2.
Again, the voltage setting resistor (R7) has to be high wattage as it is across the 100V output. Initially I used three 3.3K 3 watt resistors in series plus a 1K 2 watt WW pot for trimming. The tempco of this resistor string has to be low for a stable output.
My requirement was for 100v at less than 10mA, mostly less than 1mA, so a moderate heatsink was used. In fact, the 240/110v transformer created most of the heat and a decision was made to mount this in a separate box.
For a 100vDC output from an unregulated 150vDC I set up each regulator to drop about 25vDC.
The XL snapshot shows the performance of the cascaded regulators (TL783+LM317) at idle current. Ambient temperature was stable at 22-23C.
Again, it takes about 40 min for the voltage to stabilise but this time the variation, once the curve flattens, is around 5mV over the next hour, an improvement over the single regulator version.
For my requirements, this is now a viable design as short term stability is likely to be much better. The second capture shows a blow-up of the last 40 min of the test.
enut11
