Author Topic: Lady Heather v6 Beta for Windows .exe  (Read 140892 times)
Offline videobelu
Re: Lady Heather v6 Beta for Windows .exe
« Reply #125 on: July 01, 2019, 01:38:09 pm »
UPDATED:  to version 6.14 Beta.
Thanks!
I try compile it on Raspbian ARMv6 (Raspberry Pi Zero W), all works fine. :-+
Now i can run Lady's on RP and turn off my main PC. 8) RP Zero W have very low power consumption, without any noise!
CPU load with VNC is high 50-90%, but it works stable.
Hi is possible to have a iso of Sd card for use on Raspberry ? I am not be able to compile the the image....
Thank you very much
Offline texaspyroTopic starter
« Reply #126 on: July 01, 2019, 04:34:39 pm »
Thanks.  Any chance there is a command that displays some info about the status of the 10 MHz ref signal?
No, unless you have a TICC or counter connected.
Offline tkamiya
« Reply #127 on: July 06, 2019, 04:23:19 am »
I have a really odd situation.  (long story short), LH successfully finds match on serial speed, parity, mode, etc. and successfully talks.  How can I find out what the "match" LH found?
« Reply #128 on: July 06, 2019, 03:35:30 pm »
When the auto-detect is doing its thing,  the setting it tries is at the top of the screen.  Also the !p keyboard command should show it.
Offline tkamiya
« Reply #129 on: July 06, 2019, 03:54:27 pm »
Thank you SIR!  You just saved me tons of time!
Yes, I know it shows the progress but it was too fast for me to read.  !p worked.
Offline tkamiya
« Reply #130 on: July 08, 2019, 02:50:09 am »
Now I have two GPSDO connected to a same PC.  I wonder if you'd entertain an idea that where it says TBOLT-"C:\Program, replace it with a custom string?
Looking at a graph, it's impossible to tell which GPS unit I'm looking at.  I know I can set a "brand name" on Analog clock, but I'd rather see it up top.
« Reply #131 on: July 08, 2019, 03:22:50 am »
/pt=string    -  will set a user defined title ('-' chars convert to spaces).
/pt - uses the receiver type and .exe file name as the title.
Offline tkamiya
« Reply #132 on: July 08, 2019, 06:29:49 pm »
Do you have any plan to support Spectracom 8195B?  The protocol seems to be proprietary.
« Reply #133 on: July 08, 2019, 07:15:08 pm »
Nope...
Offline videobelu
« Reply #134 on: July 09, 2019, 08:41:40 pm »
Hi I'm trying to use Lady Heather with my GPSDO ZYT GPSDO 2019, internally it's a Symmetricom with FURUNO GT-8031T receiver.
The program correctly recognizes the UCCM protocol and apparently seems to work correctly, but after a few hours of use the system freezes and I have to turn the GPSDO off and on again and then restart the program.
Does anyone have experience with this?
Can it be a configuration problem ??
Thank you
Fabrizio
Offline Conrad Hoffman
    • The Messy Basement
« Reply #135 on: July 14, 2019, 02:28:10 pm »
I've been playing with Lady Heather and an old Magellen Explorist 210. I wanted to see how good I could do with elevation, given some averaging. It's not bad, but some other interesting things showed up. The most interesting is that the reported time can be off quite a bit. Apparently, the 210 has some internal quirks where the time isn't updated properly, and it can drift off by many seconds over time. Only a full reset can get it back in sync. I've seen it off by up to 15 seconds in the past. I think the error is also reflected in Lady Heather, but haven't proven it yet. There's also some timing problem, as I get continuous red tics on the chart. Not sure why, but the legend for the chart always gives the elevation in meters, but labels it as feet.
Of all the inexpensive modules on the 'bay, can anyone suggest something troublefree that I can eventually set up as a GPSDO of decent quality? At the moment I'm a bit lost in the woods because there are so many options.
Offline kj7e
  • Damon Stewart
« Reply #136 on: July 14, 2019, 03:22:16 pm »
Conrad,
I would recommend this unit.  The 8663 OCXO is top notch and the Star 4 GPS plays well with LH.
https://www.ebay.com/itm/10Mhz-GPSDO-OSCILLOQUARTZ-OSA-OEM-GPS-GPSDO-10MHz-1PPS-STAR-GPS-Clock/262861459973?hash=item3d33c39205:g:sbYAAOSwh2xYAjrp
The following users thanked this post: Conrad Hoffman, 2N3055
« Reply #137 on: July 23, 2019, 04:44:18 am »
I'm looking for v6.15 or later for Linux. I have found v5 (https://github.com/jkingan/ladyheather) but it doesn't recognize my Samsung UCCM-LP GPSDO.
Check the first post.  V6.14 is the latest public release.
The following users thanked this post: ZL1CVD
Offline ZL1CVD
« Reply #138 on: July 23, 2019, 07:24:27 am »
Downloaded 16.14 in Xubuntu
unzipped to folder
make clean
make
Compiled without error and worked great - I already had dependencies installed (readme.txt)
However every time I started it (./heather) is failed opening com port.
Problem was permissions. You have to add user to dialout group with..
sudo adduser <username> dialout
Great job - much more responsive than Windows - not sure why!
Offline Electro Fan
« Reply #139 on: July 23, 2019, 07:51:47 pm »
Conrad,
I have the same model but I haven't been able to figure out what commands would produce the chA ADEV, HDEV, MDEV, and TDEV tables, or the corresponding graphics (as shown in the seller's eBay photo below).  Also, I haven't been able to figure out what command would show anything about the specific frequency the GPSDO is outputting somewhere around 10 MHz.  Any suggestions on how to invoke these features in LH would be appreciated.  Thx
« Reply #140 on: July 23, 2019, 11:00:41 pm »
That screen dump was from a TAPR TICC time interval counter.
Offline bnz
« Reply #141 on: July 27, 2019, 08:41:01 am »
Hello texaspyro
would it be possible to add support for the Tekelec-Systems/Spectracom Epsilon Clock Model EC1S? It is not recognized by the current beta.
Its User manual is found here:
https://www.orolia.com/documents/users-manual-epsilon-clock-model-ec1s
From its look from the backside, the build in GPS receiver, should be a Motorola M12 Oncore.
Best regards
bnz
« Reply #142 on: July 27, 2019, 06:26:54 pm »
Not without having one to develop the software with...
« Reply #143 on: August 18, 2019, 05:42:17 pm »
That's one weird signal level map... what's to the west?
Offline JohnPi
« Reply #144 on: August 25, 2019, 06:47:00 pm »
I have this and it is running well. However the manual is a bit cryptic.
I want the clock display to show satellite signal strength vs angle -- like this -- but I can't figure out how to do it.
What is the command line and screen options for this ? I have tried things like 'SAS' but that doesn't work.
« Reply #145 on: August 29, 2019, 02:41:45 am »
Try the GB command... it toggles enabling of drawing maps, etc to the right of  the plot area.
Offline Dwaine
« Reply #146 on: September 05, 2019, 06:38:05 am »
Conrad,
I had mine for about almost a year now.   No problems with it yet.   I do noticed the sellers picture of the square wave and wonder what magical scope he has.
This is what I see when terminated with 50ohm tapping the square wave pin.
Offline Andreas
« Reply #147 on: September 05, 2019, 09:25:35 am »
you should also reduce the number of samples to 250/s and use the 1Hz output.
with best regards
Andreas
Offline tkamiya
« Reply #148 on: September 05, 2019, 12:04:29 pm »
Oscilloquartz 8663 has few versions.  Some output square wave and some do sine.  It also has 5MHz or 10MHz.
Offline Ohm_My
« Reply #149 on: September 27, 2019, 10:00:19 am »
I've acquired a SparkFun GPS-RTK2 F9P receiver and am having an issue with LH 6.0b. I've set the receiver type to /rxut but I still can't see any satellites in the table view or signal strength maps, etc?
What is the secret hand shake for this?
