Author Topic: LM399 based 10 V reference  (Read 776968 times)
Offline David Hess
  • DavidH
Re: LM399 based 10 V reference
« Reply #1450 on: October 30, 2024, 01:59:42 pm »
From the stability and simplicity it is hard to beat the resistor from the 10 V output. Even when build with separate drive and sense it is still the preferred solution.
It does have the disadvantage of adding a second order error from positive feedback because the bias current increases with output voltage, but I assume this error is insignificant.
Ratiometric sensors, including strain gauge bridges and RTDs, may add this error deliberately to improve linearity, in some cases by a lot.  I think bandgap references also use this error or something like it for bow correction over temperature.
Online Kleinstein
« Reply #1451 on: October 30, 2024, 03:50:57 pm »
The reference is stable and thus not really much of 2nd order error. There is a tiny bit of amplification of effect like the TC, but this is minute. With some 3 K from 10 V to provide 1 mA and 0.5 ohm typical impedance for the LM399 this would be some 1.0002 fold gain on the TC or similar drifts. So nothing to even notice. Even for the 1N82x zeners with there 20 times high impedance and 8 x higher current the positive feddback is still a non issue. What changes is that current source and TC of the resistor can start to matter.
With the LM399 with the rather low impedance the current source is not critical. So other solutions will also work, though more complicated and still most of them less accurate (even if it does no matter). With a roughly 14000 fold (7 V / 1 mA / 0.5 ohm) attenuation of drift the qualtiy of the resistor is not that critical (just don't use low grade carbon).
Online mawyatt
« Reply #1452 on: October 30, 2024, 03:59:12 pm »
A similar means (+ feedback) was employed with the Caprio Quad Cell based differential amplifier to improve linearity.
Best
~Wyatt Labs by Mike~
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #1453 on: January 05, 2025, 02:18:45 pm »
Hi everyone!
Long time since I last had free time to play with electronics, and I just discovered a couple days ago 4 LM399 that I ordered from Aliexpress some 5-7 years ago.
Do they look fake?
They all have burn marks, seeming to have been extracted from some equipment. They all have gold plated leads, all have some solder in the end.
I would like to just make a basic PCB to learn how to use KiCAD since I no longer have Altium and Kicad 8 seems pretty nifty.
This would be just to say that I have a voltage reference and to leave them aging, maybe some day I will get a decent multimeter.
I read some 10 pages back on this topic, plus a couple of the initial ones, is there any "recommended" design, or just go with the basic from the datasheet, since I'm not hunting for 10.0000V..
Best regards.
Online Kleinstein
« Reply #1454 on: January 05, 2025, 02:38:04 pm »
The chips look legit as reclaimed parts. The LM399 are normally quite robust, but there could still be a damaged one.
The standard circuit is with amplification to some 10 V and providing the current for the zener from there. So a bit like the "portable calibrator" circuit in the data-sheet, but without the trimmer. Depending on the amplifier used one may not need the 200 K for the start up.
I could make sense to also have an extra output for buffered 7 V.
The following users thanked this post: senso
Offline Overspeed
« Reply #1455 on: January 05, 2025, 03:59:27 pm »
Hi everyone!
Do they look fake?
Best regards.
Hello
On Github : https://github.com/circuitvalley/LM399_Voltage_reference
Not tested but with all data to be able to check including gerbers
Regards
OS
« Last Edit: January 05, 2025, 04:01:01 pm by Overspeed »
Offline ivo
« Reply #1456 on: April 16, 2025, 05:41:05 pm »
Best regards.
If you want simple, you can follow along with IMSAI Guy's design-
Online iMo
  • Country: mn
« Reply #1457 on: April 21, 2025, 05:54:07 am »
..there are definitely better designs here than the IMSAI's one..
Offline Overspeed
« Reply #1458 on: April 22, 2025, 07:24:09 am »
Hello
Could be interesting to create a post with the ( one ) best solution circuit ? or even link the Gerber files or PCB design tips as ground plane , thermal control ....
Regards
OS
« Last Edit: April 22, 2025, 11:56:43 am by Overspeed »
