LM399 are interesting parts and i have quite a few, i was thinking to adjust the zener current and try to find the zero t.c temperature for a couple of unheated samples. My plan is to use my old calibration equipment to get the zero t.c zener current.
The plan.
1: Use my Tek Know TC400 dry well and ice bath to set the temperature.
2: Using my process calibrator i can generate different zener currents for the references to find the optimal value.
3: Read/plot zener current, zener output voltage and temperature using the process calibrator and a Datron 1071 for precision voltage measurements.
The equipment specifications.
TEK know TC-400
TEMPERATURE RANGE: ~Ambient to 400°C
ACCURACY ±0.3°C
STABILITY ±0.03°C
RESOLUTION 0.01°
Process calibrator specifications: Voltage range 60V with 0.01mV resolution, Current generation range 0…25 mA uncertainty about 1.1-3uA
The Datron 1071 is 7.5 digits and quite stable over time so it should do alright in these tests.
Soon when i get some vacation time of work i will start working on this
