Author Topic: Low cost 60V reference voltage  (Read 3073 times)
Offline babysitterTopic starter
  • pushing silicon at work
« on: July 17, 2018, 11:00:19 pm »
Dear fellow volt-nuts,
I finally found a good job for those cheap, lying mains testers:
Just attach a third wire between the neon lamp and the resistor and enjoy stable 60.000 mV! This absolutely new method of voltage stabilisation was presented by yours truly at the local makerspace.
« Last Edit: July 17, 2018, 11:03:31 pm by babysitter »
I'm not a feature, I'm a bug! ARC DG3HDA
Online thermistor-guy
Re: Low cost 60V reference voltage
« Reply #1 on: July 18, 2018, 12:47:51 am »
Neon (and similar) lamps have been used as zener-like shunt regulators for quite a while:
https://en.wikipedia.org/wiki/Neon_lamp#Voltage_regulation
It's a good idea, though. Cheap and effective.
« Reply #2 on: July 18, 2018, 06:48:07 am »
Of course I am aware of VR tubes (was playing with a 0G3 a few months ago) which employ the same process, I was just joking about it being new.
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #3 on: July 18, 2018, 11:10:53 pm »
Im aksing myself if you are aware of the fact that neons have a voltage tolerance of a few Volts, not millivolts ...
Offline borghese
  • Country: si
« Reply #4 on: July 19, 2018, 05:00:48 am »
You have also a sigificant overvoltage before the lamp discharge
Cheers
Borghese
Offline markce
« Reply #5 on: July 19, 2018, 04:52:42 pm »
Still have a working 3 1/2 digit Philips DVM from 1971 with ZZ1000 as reference. That is 81V +/- 1.5%, 15ppm/C
« Last Edit: July 19, 2018, 05:10:12 pm by markce »
Offline iMo
  • Country: pm
  • It's important to try new things..
« Reply #6 on: July 19, 2018, 05:30:57 pm »
From 26:52  8)
Offline Wolfgang
« Reply #7 on: July 19, 2018, 06:06:41 pm »
The tempco is not bad at all for the 70ies, but +/-1.5% accuracy is not overwhelming. What about drift and lifetime ?
« Reply #8 on: July 19, 2018, 06:33:40 pm »
I used it to show a relative newcomer to electronics, making extensive fun of the ubiquitility...ness yet uselessness of those things. I always stress that you shouldn't use it to test for mains but give acceptable screwdrivers. Also, extra points for a voltage tester labeled by the Wau Holland Foundation...
Shortly before midnight.
Yes, of course. Still, I was able to prove my point, varying the supply about a dozen volt gave just a few hundred mV variation on the "oh-so-professional DMM."
I know. And the light dependency. And possible radioactive start-boosting agents.
And I like the ways things have been done in the past.  ^-^
Offline Wolfgang
« Reply #9 on: July 19, 2018, 07:12:24 pm »
A small sip of nostalgia from time to time is probably not harmful.  :)
Offline markce
« Reply #10 on: July 19, 2018, 07:22:21 pm »
Regular calibration is needed. Drift is 'only' 3700ppm for the first 1000h.
Expected lifetime is 30000h.
Offline Wolfgang
« Reply #11 on: July 19, 2018, 08:09:23 pm »
What were the alternatives in the 70ies ? I guess heated references ? Or something else like Silver cells ?
Offline markce
« Reply #12 on: July 19, 2018, 08:50:33 pm »
The PM2422 DMM is from 1971, but is a development from the late 60's.
In 1968 Valvo announced the BZX48 silicium reference diode, which is 6.5V, 10ppm/C
« Last Edit: July 19, 2018, 10:48:22 pm by markce »
The following users thanked this post: Wolfgang
« Reply #13 on: July 20, 2018, 08:22:28 am »
I've got a old Fluke differential voltmeter in the basement, old enough to be manufactured by John Fluke himself. It has a Weston element as internal reference and you use this by means of a "cal. switch" to adjust the +500V rail that is used to generate voltages by means of a divider.  The 500V is derived from a +85 voltage regulator tube employing glow-discharge, btw.
The weston element is a tasty slur of hazardous heavy metals and their salts in a fragile glass envelope, giving relatively stable 1,something volts. The omniscient landfill called internet gave mercury cells as another type of reference battery acceptable for some uses like light meters.
