Hi, I’m starting this thread to document the project that I have done to make a (hopefully) quite precise high voltage amplifier.
Since my HP 3245A Universal source does not have the HV option (a 10x amplifier based on the Apex PB58), I have been exploring ways to replicate its functionalities, without spending too much…
I have settled on using a PA88 HV op-amp, not as powerful or fast as the PB58 but can work at higher voltage.
More info here
https://www.apexanalog.com/products/pa88.htmlAs the PA88 supports s 450V supply it allows me to do +-200DC if configured as a 20x amplifier (using the HP 3245A as a voltage source for +-10V). AC performance is limited by the slew rate; I will make some “plots” in the next few days, but I can say that it is flat to a few kHz at 100V RMS and can do audio frequencies at 20V RMS.
Noise Is quite low, and dominated by the noise of the HP 3245A ADC.
The amplifier board is designed following the datasheet with an attempt to add DC offset correction.
The gain is set using 5ppm/K° resistors 2x50K and 5.1k, trimmed with a regular resistor and a multitourn trimmer 160ohm +10ohm.
It is in general stable but drifts at high voltage. This is quite pronounced above +-100V, probably related to self-heating of the Feedback resistors (2x50Kohm). Initially, I was planning to use much higher resistors 2x470K but that led to oscillation, probably something in between would be best such as 2x100K.
The DC offset of these op-amps is in itself quite respectable; on my particular sample, I was getting 2/3mV of offset on the output without any correction and a short on the input.
With the correction circuit, I can lower it about 15 times, but it is not quite stable enough. And will still hover around +-0.10mV.
To summarise, at low voltage the performance is limited by the DC offsets
At high voltage it is limited by the gain drifting because of self heating
In the frequency domain it is limited by the 8 V/µs slew rate
I think it makes a decent extension to the HP 3245A or a PDVS 2 mini and can be used to calibrate 4.5 Digits multimeters.
The power supply section is based on a design by
https://www.changpuak.ch/electronics/VB408.php It uses 2 A41-25-230L Transformers; these transformers can be configured both for 115V and 220V input. It should be able to provide +- 212 V in excess of 100 mA but is currently configured to limit at around 60mA. The supply is stable and low noise.
Amplifier board visible here:
https://kicanvas.org/?github=https%3A%2F%2Fgithub.com%2FpignoniG%2FPA88-based-HV-amp-200v%2Ftree%2Fmain%2FAmplifierPower supply board visible here:
https://kicanvas.org/?github=https%3A%2F%2Fgithub.com%2FpignoniG%2FPA88-based-HV-amp-200v%2Ftree%2Fmain%2FPowersupplyAnd source here:
https://github.com/pignoniG/PA88-based-HV-amp-200vI currently have populated an older version of the PCB than what is published on GitHub; this version did not include offset compensation so it comes with many bodges. I will receive the new versions in a few days and I will do some characterisation then.
In the mean time I hope this can be interesting and any comment/suggestion to improve things is welcome
