Author Topic: Measuring nanoamps and below like a Ninja  (Read 101954 times)
Offline shodan@micron
  • Country: ru
  • Ampnuts
    • My personal page
Re: Measuring nanoamps and below like a Ninja
« Reply #375 on: June 20, 2022, 10:17:20 am »
In order to see secondary electron generation the vacuum would indeed need a turbo, but the system would probably also need baking and very careful consideration of leakages, both real and virtual.
Yup.... "I=e*f" method is need some lab-grade equipment, but they still can be reproduce at home.
Some detail about that method see into patent RU 2 478 974 C2
#Stop_voltnuts_become_ampnuts
Open Science Hardware is best weapon for conquest entire galaxy!!!
My weapon OSHW repositories, link.
The following users thanked this post: Atomillo
  • Country: ru
  • Ampnuts
    • My personal page
« Reply #376 on: June 20, 2022, 09:33:06 pm »
On past week i'm ordered 100 meters of AVK-6  cable directly on factory "JSC 'OKB KP'" (Special Design Bureau of Cable Industry) at less 680 USD per 100m.
Ohhhh.... i can't stop.... today found new toy into JSC 'OKB KP' storage, it's hot chicks is called "86 meters of AVKTM-1".
It will be very interesting to connect it to my vibrator for compare performance with AVK-6.
« Last Edit: June 20, 2022, 09:46:45 pm by shodan@micron »
The following users thanked this post: HighVoltage, ch_scr, MegaVolt, Anders Petersson
  • Country: ru
  • Ampnuts
    • My personal page
« Reply #377 on: June 23, 2022, 06:14:00 am »
Online MrYakimovYA
  • Country: ru
« Reply #378 on: June 24, 2022, 02:00:29 am »
Micron-GLIN v.2 PCB repository: https://github.com/shodanx/Micron-GLIN-v.2
Micron-GLIN v.2 schematic book: https://ampnuts.com/wp-content/uploads/2022/06/Micron-GLIN-v.2-schematic-book.pdf
Hi!
Could you tell me what are you using as PE (Protection Earth) in your wall socket? Has your home PE conductor? As far as I know only modern russian home buildings have an earth protection system... Mine doesn't have it(((
  • Country: ru
  • Ampnuts
    • My personal page
« Reply #379 on: June 24, 2022, 02:03:22 pm »
I don't have any earth pin into my wall sockets. As many houses.
Therefore i use pack of metals pole which i'm installed several years ago into garden, and thick cable lifted at several floors for connect lab.
« Last Edit: June 24, 2022, 02:14:13 pm by shodan@micron »
  • Country: ru
  • Ampnuts
    • My personal page
« Reply #380 on: June 29, 2022, 12:35:37 pm »
Firmware progress:
User interface - still in progress.
Main functionality - expanded with automatic recalculation ramp speed trough saved capacitors into EEPROM, for set current directly in amperes.
  • Country: ru
  • Ampnuts
    • My personal page
« Reply #381 on: July 01, 2022, 11:25:22 am »
About capacitance for create current.
Unfortunately vacuum capacitors shows unacceptable leakage through glass. I've try use metals ring and ring of graphite coating to add guard ring directly on glass, but isn't help.
For large capacitance 10pF, 100pF, 1nF, 10nF, and high value resistors i planned use full sapphire based electrometric relays-switch, witch i'm extracted from U5-11 v.2 soviet amplifier.
It be separate project of programmable electrometic tool for use together with GLIN and [spoiler!]electrometer[spoiler!].
For less 10pF capacitance i use separate capacitors.
Now i work on algorithm of digital compensate leakage and parasitic effects of large capacitors through realtime ramp speed correction.
Hope push commit to GitHub soon and make cool video after complete GLIN firmware.
Amp-porn: The switch (input jack is also sapphire based triax)
« Last Edit: July 01, 2022, 11:57:53 am by shodan@micron »
The following users thanked this post: SilverSolder, ch_scr, Atomillo
  • Country: ru
  • Ampnuts
    • My personal page
« Reply #382 on: July 02, 2022, 07:58:55 am »
Today mining results...
16 pcs sapphire, low charge injection relays Tg5.289.049
16 pcs sapphire small female triax. (2 pcs already used in project)
1 pcs sapphire big male triax.
Leakage each parts is less 100aA at 10V. Typically is ~10-20aA after several hours(up to days) hold at 10V.
But that parts don't liked change of potential, because sapphire rings discharged very slow to aA levels.
That scrap i extract from useless, but very rich V7E-42 external switch.
Unfortunately Fortunately!!! that switch not supported by V7E-42 electrometer, and used as full separate part with some separate external controller(type is unknown, not part of the electrometer kit).
Also build quality of that external switch is low... often air gaps between low quality PCB and relays pin is zero... :palm:
I'm think that switches be made for only one purpose: to be disassembled by next generation of crazy ampnuts  >:D
Note: Tg5.289.049 relays designed for soldering to PCB by 3 of 6 pins (coil and case), 3 electrometrical pin not connected to any PCB traces, they used only for air wiring technique.
« Last Edit: July 02, 2022, 08:32:48 am by shodan@micron »
The following users thanked this post: doktor pyta, ch_scr
  • Country: ru
  • Ampnuts
    • My personal page
« Reply #383 on: July 10, 2022, 01:08:24 am »
Ouch!
Today I caught myself on idea "that it would be good practice to make a Swiss knife from GLIN".
I started integrating the LEA-M8F module to the timebase board for provide time-autocalibration and disciplined oscillator features. And I also started thinking about installing an low INL ADC to "Output board" for self-calibrate INL of DAC and add electrometer functionality to GLIN.
I need to go group therapy urgently!!!! Otherwise it be a second long-long project like as my Ultra-Micron project witch i develop around 4 years....
« Last Edit: July 10, 2022, 01:10:53 am by shodan@micron »
Offline macaba
« Reply #384 on: July 10, 2022, 12:25:36 pm »
If you're enjoying it, then don't worry about it, I'll read your updates for the next 4 years!
Your modular approach means that you can get v1 working quickly and if you've still got motivation, carry on with upgrades.
Do you know which low INL ADC you might use?
  • Country: ru
  • Ampnuts
    • My personal page
« Reply #385 on: July 10, 2022, 09:45:02 pm »
Yes, fun it is most important!
V1 not modular, it be single PCB concept. But they shows - that idea is working.
V2, yes is modular now, main pros is easy to change everything.
PS. V2 alfa version of firmware is complete... lets try make video... >:D
I'm not sure yet.
Need consult with my smugglers. I dont know yet, what ADC they can get.
« Last Edit: July 10, 2022, 09:48:13 pm by shodan@micron »
  • Country: ru
  • Ampnuts
    • My personal page
« Reply #386 on: July 11, 2022, 03:53:55 am »
Amp-porn movie: testing user interface and main functions of new GLIN with 1nF capacitor.
https://ampnuts.com/micron-glin-v2-porn/
The following users thanked this post: e61_phil, ch_scr
Online HighVoltage
« Reply #387 on: July 11, 2022, 06:28:10 am »
You have very interesting projects
Thanks for sharing
Online ch_scr
« Reply #388 on: July 11, 2022, 07:20:54 am »
Seems like your effort paid out and this one works even better than the last one, good job! Would you share a picture of how the capacitor was hooked up?
  • Country: ru
  • Ampnuts
    • My personal page
« Reply #389 on: July 11, 2022, 07:32:53 am »
good job!
Thanks! Glad to hear it!
I use this simple tool. One jack is BNC for connect to GLIN, other is Molex 3-lug triax, connected via 1.5m cable to electrometer (Keysight 16494A-001 cable).
So far, I have not paid much attention to capacitors yet and other things out of GLIN. But try share more time for caps and tools....
PS.Now need make case for GLIN....
Online ch_scr
« Reply #390 on: July 11, 2022, 08:10:31 am »
Wow, and for ground return current, just screws / washers biting through aluminium oxide layer are enough?  :scared:
That's... mostly an accidental path? Is there actually a DC connection between the two outer connector shells?
Or will return current take long way around device grounding loop? I'm surprised it's this good like this?!  :o
  • Country: ru
  • Ampnuts
    • My personal page
« Reply #391 on: July 11, 2022, 08:35:55 am »
No ground current, because signal ground of electrometer is inner shield.
Inner shield(signal ground) connected to outer shield(electrometer case ground) only into a single point. (on rear terminals)
Signal ground of electrometer provide only one feature in this connection - guarding of inner core of cable. (not used, just floating into capacitor box)
GLIN is full isolated circuits, moreover, main toroidal transformer of GLIN contains shield winding to minimize winding capacitance.
I'll try show circuit later...
« Last Edit: July 11, 2022, 08:47:05 am by shodan@micron »
  • Country: ru
  • Ampnuts
    • My personal page
« Reply #392 on: July 11, 2022, 09:19:35 am »
You means resistance of Aluminum oxide layer?
Wall end of aluminum box parts is vanished from paint to provide good connections between outer shield of a triax and shield of GLIN cable.
Aluminum oxide layer is may provide problems, but magic is - you can put some KOhm  resistor between signal ground of a GLIN and ground of a electrometer without any problem. You may add any offset between grounds... Electrometer can contains any input bias.... Ramp through capacitor is eliminate any offset to negligible.
I=C*dU/dt - no static U or R parts into formula :)
Otherwise - if you generate current with HiMeg resistors, electrometer input bias is important error source. Because I=U/R, it means - any parasitic voltage or resistance factors add an error.
« Last Edit: July 11, 2022, 09:36:33 am by shodan@micron »
Online ch_scr
« Reply #393 on: July 11, 2022, 09:31:25 am »
Thank you, that answers my question.
  • Country: ru
  • Ampnuts
    • My personal page
« Reply #394 on: July 18, 2022, 01:47:41 am »
:palm:
Yes... it starts looks like as Swiss knife...
Next revision of "Timebase board":
10MHz OCXO is disciplined now, also added two output for 1PPS and 10MHz disciplined clocks.
« Last Edit: July 18, 2022, 02:17:39 am by shodan@micron »
  • Country: ru
  • Ampnuts
    • My personal page
« Reply #395 on: July 19, 2022, 12:34:48 am »
Redesign complete, PCB ordered today :popcorn:
Offline branadic
  • Sounds like noise
« Reply #396 on: July 19, 2022, 07:09:22 pm »
What's the purpose of magic voodoo slots around OCXO? Is it just for the fancy look of it?  :-//
-branadic-
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
  • Country: ru
  • Ampnuts
    • My personal page
« Reply #397 on: July 19, 2022, 07:34:10 pm »
This is anti-crysis  ;D slots, it helps save heat and drop down power consumption.
  • Country: ru
  • Ampnuts
    • My personal page
« Reply #398 on: July 20, 2022, 05:42:14 am »
Fortunately  ;D my Symmetricom 58532A GPS L1 reference antenna do not support GLONASS and BeiDou, therefore need build my own GNSS antenna.
« Last Edit: July 20, 2022, 09:08:12 am by shodan@micron »
  • Country: ru
  • Ampnuts
    • My personal page
« Reply #399 on: July 21, 2022, 09:49:42 pm »
Ok, lets try build antenna after 1-1.5 months. My supplier say: we can try get the biggest Taoglas antenna GGSFTP.50.7.A.08 for nuts.  :popcorn:
It's large 50*50*7mm patch antenna, with better gain.
PCB dimensions also optimized for that antenna. (70*70mm)
Unfortunately that PCB must be 4 layers board with 125um prepreg for hit impedance easy, it a little bit more expensive, but i'll try order anyway.
It be a my first PCB for such high frequency.(1.56...1.6GHz) Earlier i'm build transceivers only for low frequency's 1...30MHz for my radio-shack.
It is very interesting to get a experience with high frequency.  ;)
Hmmmm.... I=C*dU/dt amp-nuttery need a high frequency and connect to satellite constellations... LTZ1000 looks too boring...  :-DD
« Last Edit: July 21, 2022, 10:28:42 pm by shodan@micron »
